ONTAP commands
vserver consistency-group show
Display a list of existing consistency groups
The command displays information for consistency groups. Use the ` instance ` parameter to display additional consistency group details.
{ [-fields <fieldname>,…​]
This specifies the fields that need to be displayed.
| [-statistics ]
Selects the last recorded historic and real time statistics for consistency group.
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Selects information about the consistency groups in the specified Vserver.
[-consistency-group <text>] - Consistency Group Name
Selects information about the specified consistency group.
[-parent-consistency-group <text>] - Parent Consistency Group Name
Selects information about the specified parent consistency group.
[-qos-policy <text>] - QoS Policy Group
Selects information about the consistency groups that have the specified QoS policy.
[-tiering-policy <Tiering Policy>] - Tiering Policy
Selects information about the consistency groups that have the specified tiering policy.
[-snapshot-policy <snapshot policy>] - Snapshot Copy Policy
Selects information about the consistency groups that have the specified snapshot policy.
[-application-type <Application type for the parent or top level CG>] - Application Type
Selects information about the consistency groups that have the specified application type.
[-application-component-type <Application component type for child CG>] - Application Component Type
Selects information about the consistency groups that have the specified application component type.
[-size {<integer>[KB|MB|GB|TB|PB]}] - Provisioned Size
Selects information about the consistency groups that have the specified size.
[-state {online|creating|deleting|modifying|restoring}] - State
Selects information about the consistency groups that have the specified state.
[-uuid <UUID>] - Consistency Group UUID
Selects information about the consistency group that matches the specified consistency group UUID.
[-create-time <Date>] - Creation Time
Selects information about the consistency groups that have the specified creation time.
[-space-available {<integer>[KB|MB|GB|TB|PB]}] - Available Space
Selects information about the consistency groups that have the specified available space.
[-space-used {<integer>[KB|MB|GB|TB|PB]}] - Space Used
Selects information about the consistency groups that have the specified used space.
[-replicated {true|false}] - Is Replicated
Selects information about the consistency groups that have the specified replicated status.
[-replication-policy <text>] - Replication Policy Name
Selects information about the consistency groups that have the specified replication policy.
[-replication-source {true|false}] - Is Replication Source
Selects information about the consistency groups that have the specified replication source.
[-vdisk-type {luns|namespaces|mixed}] - Consistency Group Type
Selects information about the consistency groups that have the specified vdisk type.
[-timestamp-metric <MM/DD/YYYY HH:MM:SS>] - Timestamp of the Sample
Selects information about the last processed consistency group statistic under the specified timestamp.
[-duration <text>] - Duration of Time Used to Measure the Sample
Selects information about the last processed consistency group statistic under the specified duration.
[-status-metric {ok|error|partial_no_data|partial_no_response|partial_other_error|negative_delta|not_found|backfilled_data|inconsistent_delta_time|partial_no_uuid|undefined}] - Status of the Sample
Selects information about the last processed consistency group statistic under the specified status.
[-available-space-metric <integer>] - Available Space in the Consistency Group
Selects information about the last processed consistency group statistic under the specified space available.
[-used-space-metric <integer>] - Space Used in the Consistency Group
Selects information about the last processed consistency group statistic under the specified space used.
[-size-metric <integer>] - Size of the Consistency Group
Selects information about the last processed consistency group statistic under the specified size.
[-latency-read-metric <integer>] - Latency of Read Operations (Us)
Selects information about the last processed consistency group statistic under the specified read latency.
[-latency-write-metric <integer>] - Latency of Write Operations (Us)
Selects information about the last processed consistency group statistic under the specified write latency.
[-latency-other-metric <integer>] - Latency of Other Operations (Us)
Selects information about the last processed consistency group statistic under the specified other latency.
[-latency-total-metric <integer>] - Total Latency over All Operations (Us)
Selects information about the last processed consistency group statistic under the specified total latency.
[-iops-read-metric <integer>] - Number of Read Operations
Selects information about the last processed consistency group statistic under the specified read iops.
[-iops-write-metric <integer>] - Number of Write Operations
Selects information about the last processed consistency group statistic under the specified write iops.
[-iops-other-metric <integer>] - Number of Other Operations
Selects information about the last processed consistency group statistic under the specified other iops.
[-iops-total-metric <integer>] - Total number of Operations
Selects information about the last processed consistency group statistic under the specified total iops.
[-throughput-read-metric <integer>] - Throughput of Read Operations (Bytes/s)
Selects information about the last processed consistency group statistic under the specified read throughput.
[-throughput-write-metric <integer>] - Throughput of Write Operations (Bytes/s)
Selects information about the last processed consistency group statistic under the specified write throughput.
[-throughput-other-metric <integer>] - Throughput of Other Operations (Bytes/s)
Selects information about the last processed consistency group statistic under the specified other throughput.
[-throughput-total-metric <integer>] - Total Throughput over All Operations (Bytes/s)
Selects information about the last processed consistency group statistic under the specified total throughput.
[-timestamp-raw <MM/DD/YYYY HH:MM:SS>] - Timestamp of the Raw Sample
Selects information about the real time consistency group statistic under the specified timestamp.
[-status-raw {ok|error|partial_no_data|partial_no_response|partial_other_error|negative_delta|not_found|backfilled_data|inconsistent_delta_time|partial_no_uuid|undefined}] - Status of the Raw Sample
Selects information about the real time consistency group statistic under the specified status.
[-available-space-raw <integer>] - Available Space in the Consistency Group
Selects information about the real time consistency group statistic under the specified available space.
[-used-space-raw <integer>] - Space Used in the Consistency Group
Selects information about the real time consistency group statistic under the specified used space.
[-size-raw <integer>] - Size of the Consistency Group
Selects information about the real time consistency group statistic under the specified size.
[-latency-read-raw <integer>] - Raw Latency over All Read Operations (Us)
Selects information about the real time consistency group statistic under the specified read latency.
[-latency-write-raw <integer>] - Raw Latency over All Write Operations (Us)
Selects information about the real time consistency group statistic under the specified write latency.
[-latency-other-raw <integer>] - Raw Latency of Other Operations (Us)
Selects information about the real time consistency group statistic under the specified other latency.
[-latency-total-raw <integer>] - Raw Total Latency over All Operations (Us)
Selects information about the real time consistency group statistic under the specified total latency.
[-iops-read-raw <integer>] - Number of Read Operations
Selects information about the real time consistency group statistic under the specified read iops.
[-iops-write-raw <integer>] - Number of Write Operations
Selects information about the real time consistency group statistic under the specified write iops.
[-iops-other-raw <integer>] - Number of Other Operations
Selects information about the real time consistency group statistic under the specified other iops.
[-iops-total-raw <integer>] - Total number of Operations
Selects information about the real time consistency group statistic under the specified total iops.
[-throughput-read-raw <integer>] - Number of Bytes of Read Operations
Selects information about the real time consistency group statistic under the specified read throughput.
[-throughput-write-raw <integer>] - Number of Bytes of Write Operations
Selects information about the real time consistency group statistic under the specified write throughput.
[-throughput-other-raw <integer>] - Number of Bytes of Other Operations
Selects information about the real time consistency group statistic under the specified other throughput.
[-throughput-total-raw <integer>] - Number of Total Bytes of All Operations
Selects information about the real time consistency group statistic under the specified total throughput.
[-clone-is-flexclone {true|false}] - Is Consistency Group a FlexClone
Selects information about the consistency group that have specified FlexClone to be true.
[-clone-source-consistency-group <text>] - Clone Source Consistency Group
Selects information about the consistency group that have specified clone source consistency group.
[-clone-source-consistency-group-uuid <UUID>] - Clone Source Consistency Group UUID
Selects information about the consistency group that have specified clone source consistency group UUID.
[-clone-source-snapshot <snapshot name>] - Snapshot Name of the Clone Source
Selects information about the consistency group that have specified clone snapshot.
[-clone-source-snapshot-uuid <UUID>] - Snapshot UUID of the Clone Source
Selects information about the consistency group that have specified clone snapshot UUID.
[-clone-parent-vserver <vserver name>] - Clone Parent Vserver Name
Selects information about the cloned consistency groups with specified clone parent Vserver
[-clone-parent-vserver-uuid <UUID>] - Clone Parent Vserver UUID
Selects information about the cloned consistency groups with specified clone parent Vserver UUID
The following command lists all the consistency groups on Vserver vs0.
vserver consistency-group show -vserver vs0
  (vserver consistency-group show)
                         Parent
           Consistency   Consistency
Vserver    Group         Group         State   Size       Available  Used
svm1       cg1           -             online     315.8MB    299.1MB     908KB
svm1       cg2           -             online     105.3MB    99.72MB     288KB
svm1       cg3           cg1           online     315.8MB    299.1MB     908KB
3 entries were displayed.
The following command shows the statistics for consistency group cg1 on Vserver vs0.
    SimpleClus::*> consistency-group show -vserver vs0 -consistency-group cg1 -statistic
                         Parent
Vserver    Group         Group
svm1       cg1           -
Last calculated statistic        Value
timestamp-metric                11/13/2023 21:11:00
duration                        PT15S
status-metric                   ok
available-space-metric          156946432
used-space-metric               344064
size-metric                     165568512
iops-other-metric               0
iops-read-metric                0
iops-write-metric               0
iops-total-metric               0
latency-other-metric            0
latency-read-metric             0
latency-write-metric            0
latency-total-metric            0
throughput-other-metric         -
throughput-read-metric          0
throughput-write-metric         0
throughput-total-metric         0
Raw statistics                  Value
timestamp-raw                   11/13/2023 21:11:02
status-raw                      ok
available-space-raw             156946432
used-space-raw                  344064
size-raw                        165568512
iops-other-raw                  0
iops-read-raw                   0
iops-write-raw                  0
iops-total-raw                  0
latency-other-raw               0
latency-read-raw                0
latency-write-raw               0
latency-total-raw               0
throughput-other-raw            -
throughput-read-raw             0
throughput-write-raw            0
throughput-total-raw            0
