vserver consistency-group show
Display a list of existing consistency groups
The command displays information for consistency groups. Use the ` instance ` parameter to display additional consistency group details.
[-fields <fieldname>,…] -
This specifies the fields that need to be displayed.
[-statistics ] -
Selects the last recorded historic and real time statistics for consistency group.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Selects information about the consistency groups in the specified Vserver.
 [-consistency-group <text>]- Consistency Group Name-
Selects information about the specified consistency group.
 [-parent-consistency-group <text>]- Parent Consistency Group Name-
Selects information about the specified parent consistency group.
 [-qos-policy <text>]- QoS Policy Group-
Selects information about the consistency groups that have the specified QoS policy.
 [-tiering-policy <Tiering Policy>]- Tiering Policy-
Selects information about the consistency groups that have the specified tiering policy.
 [-snapshot-policy <snapshot policy>]- Snapshot Copy Policy-
Selects information about the consistency groups that have the specified snapshot policy.
 [-application-type <Application type for the parent or top level CG>]- Application Type-
Selects information about the consistency groups that have the specified application type.
 [-application-component-type <Application component type for child CG>]- Application Component Type-
Selects information about the consistency groups that have the specified application component type.
 [-size {<integer>[KB|MB|GB|TB|PB]}]- Provisioned Size-
Selects information about the consistency groups that have the specified size.
 [-state {online|creating|deleting|modifying|restoring}]- State-
Selects information about the consistency groups that have the specified state.
 [-uuid <UUID>]- Consistency Group UUID-
Selects information about the consistency group that matches the specified consistency group UUID.
 [-create-time <Date>]- Creation Time-
Selects information about the consistency groups that have the specified creation time.
 [-space-available {<integer>[KB|MB|GB|TB|PB]}]- Available Space-
Selects information about the consistency groups that have the specified available space.
 [-space-used {<integer>[KB|MB|GB|TB|PB]}]- Space Used-
Selects information about the consistency groups that have the specified used space.
 [-replicated {true|false}]- Is Replicated-
Selects information about the consistency groups that have the specified replicated status.
 [-replication-policy <text>]- Replication Policy Name-
Selects information about the consistency groups that have the specified replication policy.
 [-replication-source {true|false}]- Is Replication Source-
Selects information about the consistency groups that have the specified replication source.
 [-vdisk-type {luns|namespaces|mixed}]- Consistency Group Type-
Selects information about the consistency groups that have the specified vdisk type.
 [-timestamp-metric <MM/DD/YYYY HH:MM:SS>]- Timestamp of the Sample-
Selects information about the last processed consistency group statistic under the specified timestamp.
 [-duration <text>]- Duration of Time Used to Measure the Sample-
Selects information about the last processed consistency group statistic under the specified duration.
 [-status-metric {ok|error|partial_no_data|partial_no_response|partial_other_error|negative_delta|not_found|backfilled_data|inconsistent_delta_time|partial_no_uuid|undefined}]- Status of the Sample-
Selects information about the last processed consistency group statistic under the specified status.
 [-available-space-metric <integer>]- Available Space in the Consistency Group-
Selects information about the last processed consistency group statistic under the specified space available.
 [-used-space-metric <integer>]- Space Used in the Consistency Group-
Selects information about the last processed consistency group statistic under the specified space used.
 [-size-metric <integer>]- Size of the Consistency Group-
Selects information about the last processed consistency group statistic under the specified size.
 [-latency-read-metric <integer>]- Latency of Read Operations (Us)-
Selects information about the last processed consistency group statistic under the specified read latency.
 [-latency-write-metric <integer>]- Latency of Write Operations (Us)-
Selects information about the last processed consistency group statistic under the specified write latency.
 [-latency-other-metric <integer>]- Latency of Other Operations (Us)-
Selects information about the last processed consistency group statistic under the specified other latency.
 [-latency-total-metric <integer>]- Total Latency over All Operations (Us)-
Selects information about the last processed consistency group statistic under the specified total latency.
 [-iops-read-metric <integer>]- Number of Read Operations-
Selects information about the last processed consistency group statistic under the specified read iops.
 [-iops-write-metric <integer>]- Number of Write Operations-
Selects information about the last processed consistency group statistic under the specified write iops.
 [-iops-other-metric <integer>]- Number of Other Operations-
Selects information about the last processed consistency group statistic under the specified other iops.
 [-iops-total-metric <integer>]- Total number of Operations-
Selects information about the last processed consistency group statistic under the specified total iops.
 [-throughput-read-metric <integer>]- Throughput of Read Operations (Bytes/s)-
Selects information about the last processed consistency group statistic under the specified read throughput.
 [-throughput-write-metric <integer>]- Throughput of Write Operations (Bytes/s)-
Selects information about the last processed consistency group statistic under the specified write throughput.
 [-throughput-other-metric <integer>]- Throughput of Other Operations (Bytes/s)-
Selects information about the last processed consistency group statistic under the specified other throughput.
 [-throughput-total-metric <integer>]- Total Throughput over All Operations (Bytes/s)-
Selects information about the last processed consistency group statistic under the specified total throughput.
 [-timestamp-raw <MM/DD/YYYY HH:MM:SS>]- Timestamp of the Raw Sample-
Selects information about the real time consistency group statistic under the specified timestamp.
 [-status-raw {ok|error|partial_no_data|partial_no_response|partial_other_error|negative_delta|not_found|backfilled_data|inconsistent_delta_time|partial_no_uuid|undefined}]- Status of the Raw Sample-
Selects information about the real time consistency group statistic under the specified status.
 [-available-space-raw <integer>]- Available Space in the Consistency Group-
Selects information about the real time consistency group statistic under the specified available space.
 [-used-space-raw <integer>]- Space Used in the Consistency Group-
Selects information about the real time consistency group statistic under the specified used space.
 [-size-raw <integer>]- Size of the Consistency Group-
Selects information about the real time consistency group statistic under the specified size.
 [-latency-read-raw <integer>]- Raw Latency over All Read Operations (Us)-
Selects information about the real time consistency group statistic under the specified read latency.
 [-latency-write-raw <integer>]- Raw Latency over All Write Operations (Us)-
Selects information about the real time consistency group statistic under the specified write latency.
 [-latency-other-raw <integer>]- Raw Latency of Other Operations (Us)-
Selects information about the real time consistency group statistic under the specified other latency.
 [-latency-total-raw <integer>]- Raw Total Latency over All Operations (Us)-
Selects information about the real time consistency group statistic under the specified total latency.
 [-iops-read-raw <integer>]- Number of Read Operations-
Selects information about the real time consistency group statistic under the specified read iops.
 [-iops-write-raw <integer>]- Number of Write Operations-
Selects information about the real time consistency group statistic under the specified write iops.
 [-iops-other-raw <integer>]- Number of Other Operations-
Selects information about the real time consistency group statistic under the specified other iops.
 [-iops-total-raw <integer>]- Total number of Operations-
Selects information about the real time consistency group statistic under the specified total iops.
 [-throughput-read-raw <integer>]- Number of Bytes of Read Operations-
Selects information about the real time consistency group statistic under the specified read throughput.
 [-throughput-write-raw <integer>]- Number of Bytes of Write Operations-
Selects information about the real time consistency group statistic under the specified write throughput.
 [-throughput-other-raw <integer>]- Number of Bytes of Other Operations-
Selects information about the real time consistency group statistic under the specified other throughput.
 [-throughput-total-raw <integer>]- Number of Total Bytes of All Operations-
Selects information about the real time consistency group statistic under the specified total throughput.
 [-clone-is-flexclone {true|false}]- Is Consistency Group a FlexClone-
Selects information about the consistency group that have specified FlexClone to be true.
 [-clone-source-consistency-group <text>]- Clone Source Consistency Group-
Selects information about the consistency group that have specified clone source consistency group.
 [-clone-source-consistency-group-uuid <UUID>]- Clone Source Consistency Group UUID-
Selects information about the consistency group that have specified clone source consistency group UUID.
 [-clone-source-snapshot <snapshot name>]- Snapshot Name of the Clone Source-
Selects information about the consistency group that have specified clone snapshot.
 [-clone-source-snapshot-uuid <UUID>]- Snapshot UUID of the Clone Source-
Selects information about the consistency group that have specified clone snapshot UUID.
 [-clone-parent-vserver <vserver name>]- Clone Parent Vserver Name-
Selects information about the cloned consistency groups with specified clone parent Vserver
 [-clone-parent-vserver-uuid <UUID>]- Clone Parent Vserver UUID-
Selects information about the cloned consistency groups with specified clone parent Vserver UUID
The following command lists all the consistency groups on Vserver vs0.
vserver consistency-group show -vserver vs0
  (vserver consistency-group show)
                         Parent
           Consistency   Consistency
Vserver    Group         Group         State   Size       Available  Used
svm1       cg1           -             online     315.8MB    299.1MB     908KB
svm1       cg2           -             online     105.3MB    99.72MB     288KB
svm1       cg3           cg1           online     315.8MB    299.1MB     908KB
3 entries were displayed.
The following command shows the statistics for consistency group cg1 on Vserver vs0.
    SimpleClus::*> consistency-group show -vserver vs0 -consistency-group cg1 -statistic
                         Parent
Vserver    Group         Group
svm1       cg1           -
Last calculated statistic        Value
timestamp-metric                11/13/2023 21:11:00
duration                        PT15S
status-metric                   ok
available-space-metric          156946432
used-space-metric               344064
size-metric                     165568512
iops-other-metric               0
iops-read-metric                0
iops-write-metric               0
iops-total-metric               0
latency-other-metric            0
latency-read-metric             0
latency-write-metric            0
latency-total-metric            0
throughput-other-metric         -
throughput-read-metric          0
throughput-write-metric         0
throughput-total-metric         0
Raw statistics                  Value
timestamp-raw                   11/13/2023 21:11:02
status-raw                      ok
available-space-raw             156946432
used-space-raw                  344064
size-raw                        165568512
iops-other-raw                  0
iops-read-raw                   0
iops-write-raw                  0
iops-total-raw                  0
latency-other-raw               0
latency-read-raw                0
latency-write-raw               0
latency-total-raw               0
throughput-other-raw            -
throughput-read-raw             0
throughput-write-raw            0
throughput-total-raw            0
