snaplock legal-hold end
Starts an operation to release legal-hold on files in the user specified path on a SnapLock compliance volume.
The snaplock legal-hold end
command is used to release legal-hold on specified file or files for a given litigation. Only a user with security login role vsadmin-snaplock
is allowed to perform this operation.
-vserver <vserver name>
- Vserver Name-
Specifies the name of the Vserver which owns the volume. The specified file or files to be released from legal-hold reside on this volume.
-litigation-name <text>
- Litigation Name-
Specifies the name of the litigation for which the file or files have to release from legal-hold.
-volume <volume name>
- Volume-
Specifies the name of the SnapLock compliance volume on which the file or files to be released from legal-hold reside.
-path <text>
- Path-
Specifies a path relative to the volume root. The path can be either a file path of the single file to be released from legal-hold or a directory path where all regular files under it must be released from legal-hold.
The following example starts a legal-hold end operation on file file1
in volume slc_vol1
vs1::> snaplock legal-hold end -litigation-name litigation1 -volume slc_vol1 -path /file1 SnapLock legal-hold end operation is queued. Run "snaplock legal-hold show -operation-id 16842773 -instance" to view the operation status.
The following example starts a legal-hold end operation on all files in the volume slc_vol1
vs1::> snaplock legal-hold end -litigation-name litigation1 -volume slc_vol1 -path / SnapLock legal-hold end operation is queued. Run "snaplock legal-hold show -operation-id 16842775 -instance" to view the operation status.
