system license add
Add one or more licenses
This command adds a license to a cluster. To add a license you must specify a valid license key, which you can obtain from your sales representative.
-license-code <License Code V2>,…
- License Code V2-
This parameter specifies the key of the license that is to be added to the cluster. The parameter accepts a list of 28 digit upper-case alphanumeric character keys.
[-use-license-file {true|false}]
- Use License File (privilege: advanced) } -
If this parameter is set to true, licenses from the local node /mroot/etc/lic_file license file will be installed if the file exists at this location.
The following example adds a list of licenses with the keys AAAAAAAAAAAAAAAAAAAAAAAAAAAA and BBBBBBBBBBBBBBBBBBBBBBBBBBBB to the cluster
cluster1::> system license add -license-code AAAAAAAAAAAAAAAAAAAAAAAAAAAA, BBBBBBBBBBBBBBBBBBBBBBBBBBBB
The following example installs the licenses from the local node "/mroot/etc/lic_file"
cluster1::> system license add -use-license-file true
