The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security saml-sp delete
PDF of this doc site
Creating your file...
Your file is ready
Delete SAML service provider for authentication
The security saml-sp delete
command is used to remove the Security Access Markup Language (SAML) Service Provider (SP). Running this command frees resources used by the SP. SAML SP services will no longer be available after the SP is removed.
If the SAML SP is currently enabled, it is necesary to first use security saml-sp modify-is-enabled
false
prior to security saml-sp delete
. The security saml-sp modify-is-enabled
false
command must be issued by a password authenticated console application user or from a SAML authenticated command interface.
This restarts the web server. Any HTTP/S connections that are active will be disrupted. |
The following example unconfigures SAML SP:
cluster1::> security saml-sp delete cluster1::>
