The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs users-and-groups privilege add-privilege
PDF of this doc site
Creating your file...
Your file is ready
Add local privileges to a user or group
The vserver cifs users-and-groups privilege add-privilege
command adds privileges to a local or Active Directory user or group.
-vserver <vserver name>
- Vserver-
This specifies the name of the Vserver.
-user-or-group-name <CIFS name>
- User or Group Name-
This specifies the name of the local or Active Directory user or group.
-privileges <Privilege>,…
- Privileges-
This specifies the list of privileges to be associated with this user or group.
The following example adds the privileges "SeTcbPrivilege" and "SeTakeOwnershipPrivilege" to the user "CIFS_SERVER\u1".
cluster1::> vserver cifs users-and-groups privilege add-privilege -vserver vs1 -user-or-group-name CIFS_SERVER\u1 -privileges SeTcbPrivilege,SeTakeOwnershipPrivilege
