system bridge firmware update
Download firmware onto the bridge so it can be updated
The system bridge firmware update
command downloads the firmware onto the bridge. The bridge needs to be rebooted for the firmware update to occur. The firmware file to be used is specified by the -uri parameter.
-bridge <text>
- Bridge Name (privilege: advanced)-
This specifies the bridge whose firmware needs to be updated.
-uri <text>
- URI (privilege: advanced)-
This parameter specifies the URI from which the firmware file is downloaded onto the bridge.
[-skip <true>]
- Skip Checking for Port Path = 2 (privilege: advanced)-
Use this optional parameter to skip the bridge path checking allowing a firmware file to be downloaded onto the bridge. Note that doing so might cause multiple device failures.
The following example updates the firmware on bridge ATTO_FibreBridge7500N_1.
cluster1::*> system bridge firmware update -bridge ATTO_FibreBridge7500N_1 -uri http://10.60.132.97/firmware.zbd
