vserver rename
Rename a Vserver
The vserver rename
command renames the Vserver. If the vserver being renamed is participating in an Inter-cluster Vserver peer relationship, all the corresponding remote clusters will be updated with the new peer Vserver name.
-vserver <text>
- Vserver-
This specifies the Vserver that is to be renamed.
-newname <vserver>
- New Vserver name (Use Fully Qualified Domain Name, For example: data.example.com)-
This specifies the Vserver's new name. The name must be a unique Vserver name in the cluster. Use a fully qualified domain name (FQDN) - for example, "data.example.com" - for the Vserver name to reduce name collisions in cluster leagues.
Maximum number of characters supported is 47, and 41 for a Vserver with subtype "sync-source". "all" is a reserved name and must not be used as a Vserver name. [-foreground {true|false}]
- Foreground Process-
This specifies whether the rename job will be run in foreground or backgound. By default, the job runs in foreground.
The following examples rename a Vserver named vs1.example.com
as vs2.example.com
, and then finally back to its original name:
(When there is no intercluster Vserver peer relationship with the vserver) cluster1::> vserver rename -vserver vs1.example.com -newname vs2.example.com (When there is at least one intercluster peer relationship with the Vserver) cluster1::> vserver rename -vserver vs1.example.com -newname vs2.example.com [Job 277] Job succeeded: Vserver rename completed successfully cluster1::> vserver rename -vserver vs2.example.com -newname vs1.example.com -foreground false [Job 278] Job is queued: Rename Vserver vs2.example.com to vs1.example.com.
