      network test-link stop-server
Stop server for bandwidth test
The network test-link stop-server command stops the network test-link server running on the designated node.
- -node {<nodename>|local}- Node Name (privilege: advanced)
Use this parameter to specify the node where the server is to be stopped.
The following example starts a server and stops it:
cluster1::*> network test-link start-server -node node1 cluster1::*> network test-link stop-server -node node1
 PDFs
PDFs
