job private pause
Pause a job
The job private pause
command pauses a private job. Private jobs are affiliated with a specific node and do not use any cluster facilities, such as the replicated database.
If you use this command to pause a job that does not support it, the command returns an error message.
Use the job private resume command to resume a paused private job.
Use the job private show command to view a list of private jobs.
-node {<nodename>|local}
- Node (privilege: advanced)-
Use this parameter to specify the node with which the private job is associated.
-id <integer>
- Job ID (privilege: advanced)-
Use this parameter to specify the numeric ID of the paused private job to be paused. A job ID is a positive integer.
[-vserver <vserver name>]
- Owning Vserver (privilege: advanced)-
Use this parameter to specify the name of the Vserver that owns the job.
The following example pauses the private job that has ID 99
on the node node1
cluster1::*> jobs private pause -node node1 -id 99
