volume file show-inode
Display file paths for a given inode
This command displays information about all the files having a given inode in a volume of a Vserver. If the -snapshot-id
or -snapshot-name
parameter is specified, the command displays file information from the Snapshot copy; otherwise, it displays the information from the active file system. The -vserver
, -volume
and -inode-number
are mandatory parameters.
If no optional parameter is specified, the command displays the following fields for all the files having the given inode:
Vserver Name
Volume Name
Inode Number
File Path
The volume file show-inode
command is only supported on flexible volumes and FlexGroup constituents.
[-fields <fieldname>,…]
If you specify the -fields parameter, the command output also includes the specified field or fields.
[-snapshot ]
If this parameter is specified, the command displays the following information:
Vserver Name
Volume Name
Inode Number
Snapshot Name
Snapshot ID
File Path
[-instance ]
If this parameter is specified, the command displays detailed information about the files matching the specified inode number. The following information is displayed:
Vserver Name
Volume Name
Inode Number
File Path
Snapshot Name
Snapshot ID
File Name
Parent Inode Number
Parent Directory Cookie
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver in which the volume or Snapshot copy is located.
-volume <volume name>
- Volume Name-
This specifies the volume in which the inode number is located.
-inode-number <integer>
- Inode Number-
This specifies the inode number whose information has to be retrieved.
[-snapshot-name <snapshot name>]
- Snapshot Name -
If this parameter or
-snapshot-id
is specified, information about the files is retrieved from the Snapshot copy instead of the active file system. - |
[-snapshot-id <integer>]
- Physical Snapshot ID } -
-snapshot-name
is specified, information about the files is retrieved from the Snapshot copy instead of the active file system. [-file-path <text>]
- File Path-
If this parameter is specified, the command displays information only about the files that match the specified file path.
[-file-name <text>]
- File Name-
If this parameter is specified, the command displays information only about the files that match the specified file name.
[-parent-inode-number <integer>]
- Parent Inode Number-
The inode number of the parent directory of the file associated with the inode. If this parameter is specified, the command displays information only about the files that match the specified parent inode number.
[-parent-dir-cookie <integer>]
- Parent Directory Cookie-
The index of the directory entry of the file in its parent directory tree. If this parameter is specified, the command displays information only about the files that match the specified parent directory cookie.
The following example displays information about all the files having the inode number 96 in the active file system of a volume named vol1 on a Vserver named vs1:
cluster1::> volume file show-inode -vserver vs1 -volume vol1 -inode-number 96 Inode Vserver Volume Number File Path --------- ------------ -------- ---------------------------------- vs1 vol1 96 /vol/vol1/file1 vs1 vol1 96 /vol/vol1/file2 vs1 vol1 96 /vol/vol1/A/file2 3 entries were displayed.
The following example displays information about all the files with inode number 96 in a Snapshot copy named mysnap. The Snapshot copy is present in a volume named vol1 on a Vserver named vs1:
cluster1::> volume file show-inode -vserver vs1 -volume vol1 -inode-number 96 -snapshot-name mysnap -snapshot Inode Snapshot Snapshot Vserver Volume Number Name ID File Path --------- ------------ -------- -------- -------- ------------------------- vs1 vol1 96 mysnap 131 /vol/vol1/.snapshot/mysnap/file1 vs1 vol1 96 mysnap 131 /vol/vol1/.snapshot/mysnap/file2 2 entries were displayed.
The following example displays detailed information about all the files with inode number 96 in a Snapshot copy named mysnap. The Snapshot copy is present in a volume named vol1 on a Vserver named vs1:
cluster1::> volume file show-inode -vserver vs1 -volume vol1 -inode-number 96 -snapshot-name mysnap -instance Vserver Name: vs1 Volume Name: vol1 Inode number: 96 File Path: /vol/vol1/.snapshot/mysnap/file1 Snapshot Name: mysnap Physical Snapshot ID: 131 File Name: file1 Parent Inode Number: 64 Parent Directory Cookie: 2 Vserver Name: vs1 Volume Name: vol1 Inode number: 96 File Path: /vol/vol1/.snapshot/mysnap/file2 Snapshot Name: mysnap Physical Snapshot ID: 131 File Name: file2 Parent Inode Number: 64 Parent Directory Cookie: 3 2 entries were displayed.
