security saml-sp status show
Display SAML service provider configuration status
The security saml-sp status show command displays the SAML Service Provider (SP) status for all nodes in the cluster.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node (privilege: advanced)
This identifies the node in the cluster.
- [-status {not-configured|config-in-progress|config-failed|config-success}]- Update Status (privilege: advanced)
This identifies the SAML SP status on the specified node.
- [-error-text <text>]- Error Text (privilege: advanced)
This identifies the error text associated with the latest saml SP update for this node.
- [-is-enabled {true|false}]- SAML Service Provider Enabled (privilege: advanced)
When this parameter is set to trueit indicates that the SAML SP is enabled on this node. Similarly, when this parameter is set tofalse, it indicates that the SAML SP is not enabled on this node.
The following example displays the SAML SP status information for all nodes in the cluster.
cluster::security saml-sp status> show Node SAML SP Status Enabled ------------------------------ --------------------- ---------- cluster-node1 not-configured false cluster-node2 not-configured false 2 entries were displayed. cluster::*>
 PDFs
PDFs
