vserver fcp ping-igroup show
Ping FCP by Igroup
This command performs a connectivity check (ping) between the FCP initiators of an igroup and the FCP LIFs for which they are configured.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Use this parameter to select the Vservers that contain initiators and FCP LIFs.
[-igroup <text>]
- Igroup Name-
Use this parameter to select the FCP initiators that belong to the specified igroup and FCP LIFs that belong to the portset that is bound to the igroup. If the igroup is not bound to a portset, then the default portset (all FCP LIFs in the Vserver), is used.
[-wwpn <text>]
- FCP initiator WWPN-
Use this parameter to select the FCP initiator WWPN.
[-lif <text>]
- LIF Name-
Use this parameter to limit the test to a subset of the FCP LIFs available for the igroup.
[-portset <text>]
- Portset-
Use this parameter to select igroups bound to the specified portset.
[-node <nodename>]
- Node-
Use this parameter to select the nodes that contain the specified FCP LIFs.
[-status {unknown|reachable|not-reachable|not-zoned|cannot-ping-same-wwpn|fcp-service-busy|lif-is-down|zone-info-not-available}]
- Ping Status-
Use this parameter to select the status of FCP ping command.
[-ext-status {logged-in|not-logged_in|not-in-fabric|not-in-same-zone|fabric-info-not-available}]
- Extended Status-
Use this parameter to select the extended status of FCP ping command.
[-check-fabric <true>]
- Query Fabric Records (privilege: advanced)-
Use this parameter to query the unzoned name server for the FCP initiator WWPN.
cluster1::> vserver fcp ping-igroup show Igroup Node Logical Ping Extended Vserver Name WWPN Name Interface Status Status --------- ----------- -------------- ---------- --------- ---------- ----------- vserver_1 igroup_1 c0:03:ff:e4:70:06:00:e4 node_1 lif_1 reachable wwpn-logged-in igroup_1 c0:03:ff:e4:70:06:00:e6 node_2 lif_2 not-zoned - 2 entries were displayed.
