cluster space modify
Modify Cluster Space Attributes
The cluster space modify can be used to modify space attributes of a cluster.
[-full-threshold-percent <percent>]- Cluster Full Threshold Percent-
This optionally specifies the percentage at which the cluster is considered full, and above which a critical EMS error will be generated.
[-nearly-full-threshold-percent <percent>]- Cluster Near Full Threshold Percent-
This optionally specifies the percentage at which the cluster is considered nearly full, and above which an EMS warning will be generated.
