cluster space modify
PDF of this doc site
Creating your file...
Your file is ready
Modify Cluster Space Attributes
The cluster space modify
can be used to modify space attributes of a cluster.
[-full-threshold-percent <percent>]
- Cluster Full Threshold Percent-
This optionally specifies the percentage at which the cluster is considered full, and above which a critical EMS error will be generated.
[-nearly-full-threshold-percent <percent>]
- Cluster Near Full Threshold Percent-
This optionally specifies the percentage at which the cluster is considered nearly full, and above which an EMS warning will be generated.
