Command reference
vserver cifs cache name-to-sid show
Display name-to-sid cache entries
The vserver cifs cache name-to-sid show command displays the Windows user information cached by Windows name.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
Use this parameter to display detailed information about the Windows user entries cached by the Windows name.
[-vserver <vserver name>] - Vserver (privilege: advanced)
Use this parameter to specify the Vserver for which the Windows user entries that are cached by the Windows name need to be displayed.
[-win-name <text>] - Windows Name (privilege: advanced)
Use this parameter to specify the Windows name for which the cached entries need to be displayed.
[-sid <text>] - SID (privilege: advanced)
Use this parameter to display information only about the cached Windows user entries that have the specified security identifier (SID).
[-sid-type <integer>] - SID type (privilege: advanced)
Use this parameter to display information only about the cached Windows user entries that have the specified security identifier (SID) type.
[-flags <integer>] - Flags (privilege: advanced)
Use this parameter to display information only about the Windows user entries cached by the Windows name that have the specified flags.
[-domain-name <text>] - Domain Name (privilege: advanced)
Use this parameter to display information only about the Windows user entries cached by the Windows name that have the specified domain name.
[-create-time <MM/DD/YYYY HH:MM:SS>] - Create Time (privilege: advanced)
Use this parameter to display information only about the Windows user entries that were cached at the specified time.
[-source {none|files|dns|nis|ldap|netgrp_byname|dc}] - Source of the Entry (privilege: advanced)
Use this parameter to display information only about the user entries cached by the Windows name that have the specified lookup source.
The following example shows how to display all of the Windows users which are cached by the Windows name:
cluster1::> vserver cifs cache name-to-sid show
The following example shows how to display all of the Windows user entries cached by the Windows name for Vserver vs0:
cluster1::> vserver cifs cache name-to-sid show -vserver vs0
