Command reference
vserver consistency-group volume add
Add a volume to the consistency group
The vserver consistency-group volume add adds existing volumes to a consistency group.
-vserver <Vserver Name> - Vserver Name
This parameter specifies the Vserver that contains the consistency group to which the volumes will be added.
-consistency-group <text> - Consistency Group
This parameter specifies the consistency group to which the volumes will be added.
[-parent-consistency-group <text>] - Parent Consistency Group
This parameter specifies the parent consistency group to which the volumes will be added.
-volume <text> - Volume
This parameter specifies the volume to be added to the consistency group.
The following example will add volumes vol1,vol2 to a child consistency group named cg in parent consistency group parentCg on a Vserver named vs0.
cluster1::> vserver consistency-group volume add -vserver vs0 -consistency-group cg -parent-consistency-group parentCg -volume vol1,vol2
          (vserver consistency-group volume add)
        [Job 100] Job succeeded: Success
