Command reference
security ipsec ca-certificate show
Displays the CA certificates added to IPsec
This command displays the configured IPsec CA certificates.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
If you specify this parameter, then the command displays only the IPsec CA certificates configured for the given vserver.
[-ca-certs <text>,…​] - CA Certificate Names
If you specify this parameter, then the command displays only the Vservers for which the given CA certificates are present in IPsec.
The following example lists the IPsec CA certificates configured for all Vservers.
cluster-1::>security ipsec ca-certificate show
Vserver              CA Certificate Names
v1                   caCert1, caCert2
v2                   caCert3, caCert4
2 entries were displayed.
