security ipsec ca-certificate show
Displays the CA certificates added to IPsec
This command displays the configured IPsec CA certificates.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Name
If you specify this parameter, then the command displays only the IPsec CA certificates configured for the given vserver.
- [-ca-certs <text>,…]- CA Certificate Names
If you specify this parameter, then the command displays only the Vservers for which the given CA certificates are present in IPsec.
The following example lists the IPsec CA certificates configured for all Vservers.
cluster-1::>security ipsec ca-certificate show Vserver CA Certificate Names ------------------ ---------------------------------- v1 caCert1, caCert2 v2 caCert3, caCert4 2 entries were displayed.
 PDFs
PDFs
