vserver migrate show-volume
Display status of volumes in a migrating Vservers
This command displays status of all the volumes in a migrating Vservers. It must be run on the destination cluster of the Vserver migrate.
[-fields <fieldname>,…] -
This specifies the fields that need to be displayed.
[-instance ]} -
If this parameter is specified, the command displays detailed volume status information.
[-vserver <vserver name>]- Vserver Name-
Name of the Vserver which is migrating.
[-volume <volume name>]- Volume Name-
If this parameter is specified, the command displays detailed volume status information that matches the specified volume.
[-volume-dsid <integer>]- Volume DSID-
If this parameter is specified, the command displays the details of volume status that matches the specified DSID.
[-volume-msid <integer>]- Volume MSID-
If this parameter is specified, the command displays the details of volume status that matches the specified MSID.
[-vserver-uuid <UUID>]- Vserver UUID-
If this parameter is specified, the command displays the details of volume status that matches the specified Vserver UUID.
[-node <nodename>]- Node-
If this parameter is specified, the command displays the details of volume status that matches the specified node.
[-volume-state {online|restricted|offline|force-online|force-offline|mixed}]- State of the Volume-
If this parameter is specified, the command displays the details of volume status that matches the specified volume state.
[-transfer-status <mirror status>]- Status of Transfer-
If this parameter is specified, the command displays the details of volume status that matches the specified transfer status.
[-healthy {true|false}]- Healthy-
If this parameter is specified, the command displays the details of volume status that matches the specified health status
[-errors <text>,…]- Errors in Volume Operation-
If this parameter is specified, the command displays the details of volume status that matches the specified errors.
cluster1::> vserver migrate show-volume -vserver test
