Command reference
vserver migrate show-volume
Display status of volumes in a migrating Vservers
This command displays status of all the volumes in a migrating Vservers. It must be run on the destination cluster of the Vserver migrate.
{ [-fields <fieldname>,…​]
This specifies the fields that need to be displayed.
| [-instance ] }
If this parameter is specified, the command displays detailed volume status information.
[-vserver <vserver name>] - Vserver Name
Name of the Vserver which is migrating.
[-volume <volume name>] - Volume Name
If this parameter is specified, the command displays detailed volume status information that matches the specified volume.
[-volume-dsid <integer>] - Volume DSID
If this parameter is specified, the command displays the details of volume status that matches the specified DSID.
[-volume-msid <integer>] - Volume MSID
If this parameter is specified, the command displays the details of volume status that matches the specified MSID.
[-vserver-uuid <UUID>] - Vserver UUID
If this parameter is specified, the command displays the details of volume status that matches the specified Vserver UUID.
[-node <nodename>] - Node
If this parameter is specified, the command displays the details of volume status that matches the specified node.
[-volume-state {online|restricted|offline|force-online|force-offline|mixed}] - State of the Volume
If this parameter is specified, the command displays the details of volume status that matches the specified volume state.
[-transfer-status <mirror status>] - Status of Transfer
If this parameter is specified, the command displays the details of volume status that matches the specified transfer status.
[-healthy {true|false}] - Healthy
If this parameter is specified, the command displays the details of volume status that matches the specified health status
[-errors <text>,…​] - Errors in Volume Operation
If this parameter is specified, the command displays the details of volume status that matches the specified errors.
cluster1::> vserver migrate show-volume -vserver test
