snapmirror mediator tba-history show
Show Mediator Agent Event History
The snapmirror mediator tba-history show command shows the history of the ONTAP Mediator Agent events..
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-cg-rel-uuid <UUID>]- Cg Relationship Uuid-
Cg Relationship Uuid.
[-start-time <MM/DD/YYYY HH:MM:SS>]- TBA Task Start Time-
Mediator Agent Task Start Time.
[-token-num <integer>]- Token Number-
Token Number.
[-cg-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}]- Cg Path-
Cg Path.
[-aux-generation-num <integer>]- Auxillary Generation Number-
Auxiliary Generation Number.
[-cg-rel-task <text>]- TBA Task Type-
Mediator Agent Task Type.
[-cg-rel-state {invalid-state|waiting|task-processing|task-complete}]- Cg Management State-
Cg Management State.
[-end-time <MM/DD/YYYY HH:MM:SS>]- TBA Task End Time-
Mediator Agent Task End Time.
[-cg-rel-action {invalid|none|continue|stop|failover-incapable|auto-failover|success|failed|mismatch|retry|success-pending|stop-pending|continue-pending|failover-incapable-pending|try-failover-incapable-ic|try-failover-incapable-med|try-auto-failover|stop-svm}]- Cg Management Action-
Cg Management Action.
[-errCode <integer>]- Error Code for Task Failure-
Error Code for Task Failure.
The following example shows the list of mediator configurations.
C1_sti89-vsim-ucs525q_cluster::> snapmirror mediator tba-history show
(snapmirror mediator tba-history show)
Path Token API Event Start Time State End Time Action
vs0:/cg/cg1_src 5 4 Process Set Resync Context 4/28/2021 11:09:52 task-complete 4/28/2021 11:09:52 continue
vs0:/cg/cg1_src 6 1 Process Master InSync 4/28/2021 11:10:08 task-complete 4/28/2021 11:10:08 success
2 entries were displayed.
C1_sti89-vsim-ucs525q_cluster::> snapmirror mediator tba-history show -instance
Cg Relationship Uuid: ad49a4f1-a833-11eb-9846-005056a7c906
Mediator Agent Task Start Time: 4/28/2021 11:09:52
Token Number: 5
Cg Path: vs0:/cg/cg1_src
Auxillary Generation Number: 4
Mediator Agent Task Type: Process Set Resync Context
Cg Management State: task-complete
Mediator Agent Task End Time: 4/28/2021 11:09:52
Cg Management Action: continue
Error Code for Task Failure: 0
Mediator Agent Task Start Time: 4/28/2021 11:10:08
Token Number: 6
Auxillary Generation Number: 1
Mediator Agent Task Type: Process Master InSync
Mediator Agent Task End Time: 4/28/2021 11:10:08
Cg Management Action: success
