Command reference
vserver vscan scanner-pool show-active
Display active scanner pools
The vserver vscan scanner-pool show-active command displays active scanner pool information available to the Vserver. The active scanner pool configuration is derived by merging the information of the scanner pools which are currently active on a Vserver. If you do not specify any parameters, the command displays the following information about all Vservers:
  • Vserver name
  • List of scanner pools
  • List of servers
  • List of privileged user
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only about the specified Vserver.
[-scanner-pools <Scanner pool>,…​] - List of Enabled Scanner Pools
If you specify this parameter, the command displays information only about the Vservers that have the specified scanner pool or pools. A scanner pool becomes part of this list if it is active at this time.
[-servers <IP Address>,…​] - Merged List of IPs of Allowed Vscan Servers
If you specify this parameter, the command displays information only about the Vservers that have the specified server or servers. Servers of all active scanner pools on a Vserver are merged to derive this effective server list.
[-privileged-users <Privileged user>,…​] - Merged List of Privileged Users
If you specify this parameter, the command displays information only about the Vservers that have the specified privileged user or users. Privileged users of all active scanner pools on a Vserver are merged to derive this effective privileged user list.
[-request-timeout <[<integer>d][<integer>h][<integer>m][<integer>s]>] - Request Service Timeout (privilege: advanced)
If you specify this parameter, the command displays information only about the Vservers that have the specified request-timeout. This is set to the maximum value of the request-timeout of all active scanner pools on a Vserver.
[-scan-queue-timeout <[<integer>d][<integer>h][<integer>m][<integer>s]>] - Scan Queue Timeout (privilege: advanced)
If you specify this parameter, the command displays information only about the Vservers that have the specified scan-queue-timeout. This is set to the maximum value of the scan-queue-timeout of all active scanner pools on a Vserver.
[-session-setup-timeout <[<integer>d][<integer>h][<integer>m][<integer>s]>] - Session Setup Timeout (privilege: advanced)
If you specify this parameter, the command displays information only about the Vservers that have the specified session-setup-timeout. This is set to the maximum value of the session-setup-timeout of all active scanner pools on a Vserver.
[-session-teardown-timeout <[<integer>d][<integer>h][<integer>m][<integer>s]>] - Session Teardown Timeout (privilege: advanced)
If you specify this parameter, the command displays information only about the Vservers that have the specified session-teardown-timeout. This is set to the maximum value of the session-teardown-timeout of all active scanner pools on a Vserver.
[-max-session-setup-retries <integer>] - Max Number of Consecutive Session Setup Attempts (privilege: advanced)
If you specify this parameter, the command displays information only about the Vservers that have the specified max-session-setup-retries. This is set to the maximum number of the max-session-setup-retry of all active scanner pools on a Vserver.
The following example displays information about active scanner pool on all Vservers.
cluster1::> vserver vscan scanner-pool show
            Scanner    Pool                         Privileged      Scanner
Vserver     Pool       Owner   Servers              Users           Policy
Cluster     clus       cluster 5.5.5.5              cifs\u5         idle
vs1         new        vserver 1.1.1.1, 2.2.2.2     cifs\u1         primary
vs1         clus       cluster 5.5.5.5              cifs\u5         idle
vs1         p1         vserver 3.3.3.3              cifs\u4         primary
vs2         clus       cluster 5.5.5.5              cifs\u5         primary
vs2         p2         vserver 3.3.3.3, 4.4.4.4     cifs\u2         primary
6 entries were displayed.
cluster1::> vserver vscan scanner-pool show-active
                                                      Privileged
Vserver     Scanner Pools      Servers                     Users
vs1         new, p1       1.1.1.1, 2.2.2.2, 3.3.3.3   cifs\u1, cifs\u4
vs2         clus, p2      3.3.3.3, 4.4.4.4, 5.5.5.5   cifs\u2, cifs\u5
2 entries were displayed.
