Command reference
lun igroup initiator remove-proximal-vserver
Remove a Vserver from the initiator's proximal list
This command is used to remove the proximal Vserver configuration from an FCP or iSCSI initiator.
-vserver <Vserver Name> - Vserver (privilege: advanced)
Specifies the name of the Vserver the initiator will access.
-initiator <text> - Initiator (privilege: advanced)
Specifies the FCP WWPN or iSCSI IQN of the initiator.
{ -proximal-vservers <text>,…​ - Proximal Vserver Name (privilege: advanced)
Specifies the name of the Vserver to remove as proximal. The specified Vserver must either be the same as the -vserver parameter or a Vserver in a peer relationship with snapmirror as an allowed application.
| -all <true> - Remove All (privilege: advanced) }
If true, remove all existing proximal Vservers from the specified initiator.
The following example configures iqn.2001-04.com.example:uefi-0232314 in Vserver local-vserver as not proximal to the peer-vserver Vserver:
cluster1::*> lun igroup initiator remove-proximal-vserver -vserver local-vserver -initiator iqn.2001-04.com.example:uefi-0232314 -proximal-vservers peer-vserver
