lun igroup initiator remove-proximal-vserver
Remove a Vserver from the initiator's proximal list
This command is used to remove the proximal Vserver configuration from an FCP or iSCSI initiator.
-vserver <Vserver Name>- Vserver (privilege: advanced)-
Specifies the name of the Vserver the initiator will access.
-initiator <text>- Initiator (privilege: advanced)-
Specifies the FCP WWPN or iSCSI IQN of the initiator.
-proximal-vservers <text>,…- Proximal Vserver Name (privilege: advanced) -
Specifies the name of the Vserver to remove as proximal. The specified Vserver must either be the same as the
-vserverparameter or a Vserver in a peer relationship withsnapmirroras an allowed application. - |
-all <true>- Remove All (privilege: advanced) } -
If true, remove all existing proximal Vservers from the specified initiator.
The following example configures iqn.2001-04.com.example:uefi-0232314 in Vserver local-vserver as not proximal to the peer-vserver Vserver:
cluster1::*> lun igroup initiator remove-proximal-vserver -vserver local-vserver -initiator iqn.2001-04.com.example:uefi-0232314 -proximal-vservers peer-vserver
