system smtape status clear
Clear SMTape sessions
This command clears SMTape sessions which are completed, failed or Unknown state.
[-session <Sequence Number>]- Session Identifier-
Use this parameter to clear the SMTape sessions with the specified session identifier.
[-node {<nodename>|local}]- Node Name-
Use this parameter to clear the SMtape sessions related to the specified node.
[-type {backup|restore}]- Operation Type-
Use this parameter to clear the SMTape sessions of the specified operation type. These can be either backup or restore sessions.
[-status {COMPLETED|FAILED|UNKNOWN}]- Session Status-
Use this parameter to clear the SMTape sessions which have the status as specified in the parameter.
[-path <text>]- Path Name-
Use this parameter to clear the SMTape sessions which have path as specified in the parameter.
[-device <text>]- Device Name-
Use this parameter to clear the SMTape sessions on a specific tape device.
[-backup-snapshot <snapshot name>]- Snapshot Name-
Use this parameter to clear the SMTape sessions using the snapshot name as specified in the parameter.
[-tape-block-size <integer>]- Tape Block Size-
Use this parameter to clear the SMTape sessions with the tape block size as specified in the parameter.
The following example clears all the completed SMTape sessions in the cluster:
cluster1::> system smtape status clear 5 sessions are purged.
The SMTape sessions on the node node1 in the cluster are cleared.
cluster1::> system smtape status clear -node node1 3 sessions are purged.
