Command reference
volume encryption secure-purge show
Show status of secure-purge operation on a volume
The volume encryption secure-purge show command displays information about volume encryption securepurge operation in the cluster.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-vserver <vserver name>] - Vserver (privilege: advanced)
This parameter specifies the Vserver on which the volume is located.
[-volume <volume name>] - Volume (privilege: advanced)
This parameter specifies the name of the volume being secure purged.
[-status {invalid|initializing|snapshots-deleting|snapshots-deleted|zombies-draining|zombies-drained|batched-free-log-draining|batched-free-log-drained|finishing-trash-purge|finished-trash-purge|reencrypting|aborting|aborted|success|failure|blocks-reclaim-scan-in-progress|blocks-reclaim-scan-completed|updating-blocks-used}] - Status (privilege: advanced)
This parameter displays the status of the secure purge operation.
The following example shows a sample output for this command:
cluster1::> volume encryption secure-purge show
Vserver       Volume          Secure Purge Phase
vs1           vol1            reencrypting
