snapmirror promote
Promote the destination to read-write
The snapmirror promote command performs a failover to the destination volume of a SnapMirror relationship. This command changes the destination volume from a read-only volume to a read-write volume and makes the destination volume assume the identity of the source volume. The command then destroys the original source volume. The destination volume must be a load-sharing volume. Note that you can promote a load-sharing volume that has been left in read-write state by a previously failed promote operation.
Client accesses are redirected from the original source volume to the promoted destination volume. The view clients see on the promoted destination volume is the latest transferred snapshot, which might lag behind the view clients had of the original source volume before the promote.
The SnapMirror relationship is always deleted as part of the promotion process.
It is possible that the original source volume is the source of multiple SnapMirror relationships. For such a configuration, the promoted destination volume becomes the new source volume of the other SnapMirror relationships.
This command is only supported for SnapMirror relationships with the field "Relationship Capability" showing as "Pre 8.2" in the output of the snapmirror show command.
The snapmirror promote command fails if a SnapMirror transfer is in progress for any SnapMirror relationship with "Relationship Capability" of "Pre 8.2" involving the original source volume. It does not fail if a SnapMirror transfer is in progress for a relationship with "Relationship Capability" of "8.2 and above" .
[-S, -source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}]- Source Path -
This parameter specifies the source endpoint of the SnapMirror relationship in one of four path formats. The normal format includes the names of the Vserver (vserver) and/or volume (volume). To support relationships with
"Relationship Capability"of"Pre 8.2", a format which also includes the name of the cluster (cluster) is provided. The"Pre 8.2"format cannot be used when operating in a Vserver context on relationships with"Relationship Capability"of"8.2 and above". For SnapMirror relationships with an AltaVault source, the source endpoint is specified in the formhostip:/share/share-name. For SnapMirror relationships with a SolidFire source, the source endpoint is specified in the formhostip:/lun/name. - |
[-source-cluster <Cluster name>]- Source Cluster -
Specifies the source cluster of the SnapMirror relationship. If this parameter is specified, the
-source-vserverand-source-volumeparameters must also be specified. This parameter is only applicable for relationships with"Relationship Capability"of"Pre 8.2". This parameter cannot be specified when operating in a Vserver context on relationships with"Relationship Capability"of"8.2 and above". [-source-vserver <vserver name>]- Source Vserver-
Specifies the source Vserver of the SnapMirror relationship. For relationships with volumes as endpoints, if this parameter is specified, parameters
-source-volumeand for relationships with"Relationship Capability"of"Pre 8.2",-source-clustermust also be specified. This parameter is not supported for relationships with non-ONTAP source endpoints. [-source-volume <volume name>]- Source Volume }-
Specifies the source volume of the SnapMirror relationship. If this parameter is specified, parameters
-source-vserverand for relationships with"Relationship Capability"of"Pre 8.2",-source-clustermust also be specified. This parameter is not supported for relationships with non-ONTAP source endpoints. - {
-destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}- Destination Path -
This parameter specifies the destination endpoint of the SnapMirror relationship in one of four path formats. The normal format includes the names of the Vserver (vserver) and/or volume (volume). To support relationships with
"Relationship Capability"of"Pre 8.2", a format which also includes the name of the cluster (cluster) is provided. The"Pre 8.2"format cannot be used when operating in a Vserver context on relationships with"Relationship Capability"of"8.2 and above". For SnapMirror relationships with an AltaVault destinations, the destination endpoint is specified in the formhostip:/share/share-name. For SnapMirror relationships with a SolidFire destinations, the destination endpoint is specified in the formhostip:/lun/name. - |
[-destination-cluster <Cluster name>]- Destination Cluster -
Specifies the destination cluster of the SnapMirror relationship. If this parameter is specified, parameters
-destination-vserverand-destination-volumemust also be specified. This parameter is only applicable for relationships with"Relationship Capability"of"Pre 8.2". This parameter cannot be specified when operating in a Vserver context on relationships with"Relationship Capability"of"8.2 and above". -destination-vserver <vserver name>- Destination Vserver-
Specifies the destination Vserver of the SnapMirror relationship. For relationships with volumes as endpoints, if this parameter is specified, parameters
-destination-volumeand for relationships with"Relationship Capability"of"Pre 8.2",-destination-clustermust also be specified. This parameter is not supported for relationships with non-ONTAP destination endpoints. -destination-volume <volume name>- Destination Volume }-
Specifies the destination volume of the SnapMirror relationship. If this parameter is specified, parameters
-destination-vserverand for relationships with"Relationship Capability"of"Pre 8.2",-destination-clustermust also be specified. This parameter is not supported for relationships with non-ONTAP destination endpoints. [-f, -force <true>]- Force-
If this parameter is specified, the command proceeds without prompting for confirmation.
To promote a mirror named vs1_root_ls1 to be the source read-write volume for mirroring and client access, type the following command:
cluster1::> snapmirror promote -destination-path
//vs1.example.com/vs1_root_ls1
-source-path //vs1.example.com/vs1_root -f true
