Command reference
lun move modify
Modify an ongoing LUN move operation
The lun move modify command modifies the maximum throughput of an ongoing move operation.
{ -vserver <Vserver Name> - Vserver Name
Specifies the name of the Vserver that will host the destination LUN.
-destination-path <path> - Destination Path
Specifies the full path to the new LUN, in the format /vol/<volume>[/<qtree>]/<lun>.
-max-throughput {<integer>[KB|MB|GB|TB|PB]} - Maximum Transfer Rate (per sec)
Specifies the maximum amount of data, in bytes, that can be transferred per second in support of this operation. This mechanism can be used to throttle a transfer, to reduce its impact on the performance of the source and destination nodes.
Note The specified value will be rounded up to the nearest megabyte.
cluster1::> lun move modify -vserver vs1 -destination-path /vol/vol2/lun2 -max-throughput 25MB
Modifies the maximum throughput for the ongoing move job identified by Vserver vs1 and destination path /vol/vol2/lun2 to 25 MB/sec.
