system smtape backup
Backup a volume to tape devices
This command performs a baseline backup of a specified volume path to a tape device. You can use the command system hardware tape drive show to view the list of tape devices in the cluster. You must specify a snapshot name to perform an SMTape backup operation. The snapshot name specified is used as the base snapshot. A new unique session ID is assigned for this SMTape operation and the status of the session can be monitored using the command system smtape status . This session ID can be subsequently used to perform other operations such as to find the SMTape status, abort an SMTape operation, and continue an SMTape operation.
The volume and tape device must reside on the same node in the cluster. You must retain the base snapshot created during this backup operation in order to use this snapshot to re-establish a SnapMirror relationship upon a restore.
- -vserver <vserver name>- Vserver Name
Use this parameter to specify the Vserver name on which the volume is located. You need not specify this parameter if only one cluster Vserver exists.
- -volume <volume name>- Volume Name
Use this parameter to specify the name of the volume that needs to be backed up to tape.
- -backup-snapshot <snapshot name>- Snapshot Name
Use this parameter to specify the name of the snapshot while performing an SMTape backup operation.
- -tape </node_name/tape_device>- Tape Name
Use this parameter to specify the name of the tape device which is used for this SMTape operation. The format of the tape device name is / node_name/tape_device, wherenode_nameis the name of the cluster node owning the tape andtape_deviceis the name of the tape device.
- [-tape-block-size <integer>]- Tape Record Size in KB
Use this parameter to specify the tape record size in KB for backup and restore operations. The tape record size is in multiples of 4KB, ranging from 4KB to 256KB. The default tape record size is 240KB unless it is specified.
The following example will start the backup of a volume datavol in a Vserver vserver0 to a tape rst0a . Both the volume and tape reside on the same node cluster1-01 . The snapshot to be backed up is datavol_snapshot and the tape record size has the value of 256KB.
cluster1::> system smtape backup -vserver vserver0 -volume datavol
    -backup-snapshot datavol_snapshot -tape /cluster1-01/rst0a
    -tape-block-size 256
Session 21 created successfully
The following example will start the backup of a volume datavol in a Vserver vserver0 to a tape rst0a . The volume datavol is in a Vserver vserver0 . Both the volume and tape reside on the same node cluster1-01 . The snapshot to be backed up is datavol_snapshot and the tape record size has the default value of 240KB.
    -backup-snapshot datavol_snapshot -tape /cluster1-01/nrst0l
Session 22 created successfully
 PDFs
PDFs
