Command reference
vserver cifs users-and-groups local-group show
Display local groups
The vserver cifs users-and-groups local-group show command displays local groups.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If this parameter is specified, the command displays information only about local groups that match the specified Vserver name.
[-group-name <CIFS name>] - Group Name
If this parameter is specified, the command displays information only about local groups that match the specified group name.
[-description <TextNoCase>] - Description
If this parameter is specified, the command displays information only about local groups that match the specified description.
The following example displays all local groups associated with Vserver "vs1".
cluster1::> vserver cifs users-and-groups local-group show -vserver vs1
Vserver        Group Name                       Description
vs1            BUILTIN\Administrators           Built-in Administrators group
vs1            BUILTIN\Backup Operators         Backup Operators group
vs1            BUILTIN\Power Users              Restricted administrative privileges
vs1            BUILTIN\Users                    All users
vs1            CIFS_SERVER\g1
vs1            CIFS_SERVER\g2
6 entries were displayed.
