security login totp delete
Delete a TOTP secret
The security login totp delete command deletes secret key for a specific user. To delete a secret key, you must specify a user name.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver of the user for whom you are deleting the secret key.
-username <text>- Username-
This parameter specifies the name of the user for whom you are deleting a secret key. If you do not specify a user in case of cserver, the user named admin is specified by default. In case of data vserver, it defaults to logged-in user
The following command deletes the secret key for the user named tsmith.
cluster1::> security login totp delete -username tsmith
