lun bind create
Bind a VVol LUN to a protocol endpoint
This command creates a new binding between a protocol endpoint and a vvol LUN. If a binding between the specified endpoint and vvol already exists, the reference count for the binding is incremented by one.
|  | For optimal results, the protocol endpoint and vvol must be hosted by the same node in the cluster. |
- -vserver <Vserver Name>- Vserver name (privilege: advanced)
Specifies the name of the Vserver.
- -protocol-endpoint-path <path>- Protocol Endpoint (privilege: advanced)
Specifies the path to the protocol endpoint. The specified LUN must already exist and be of class "protocol-endpoint". Examples of correct LUN paths: /vol/vol1/lun1and/vol/vol1/qtree1/lun1
- -vvol-path <path>- VVol Path (privilege: advanced)
Specifies the path to the vvol. The specified LUN must already exist and be of the class "vvol". Examples of correct LUN paths: /vol/vol1/lun1and/vol/vol1/qtree1/lun1
cluster1::*> lun bind create -vserver vs1 -protocol-endpoint-path /vol/VV1/PE1 -vvol-path /vol/VV3/234ace
Bind the vvol /vol/VV3/234ace to the protocol endpoint /vol/VV1/PE1 in Vserver vs1.
 PDFs
PDFs
