Command reference
vserver cifs users-and-groups local-group show-members
Display local groups' members
The vserver cifs users-and-groups local-group show-members command displays members of a local group. The members can be local or Active Directory users or groups.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If this parameter is specified, the command displays group members of local groups that match the specified Vserver name.
[-group-name <CIFS name>] - Group Name
If this parameter is specified, the command displays group members of local groups that match the specified group name.
[-member <CIFS name>,…​] - Member Name
If this parameter is specified, the command displays group members that match the specified member name. The name can be that of a local user, Active Directory user, or Active Directory group.
The following example displays members of local groups associated with Vserver "vs1".
cluster1::> vserver cifs users-and-groups local-group show-members -vserver vs1
Vserver        Group Name                   Members
vs1            BUILTIN\Administrators       CIFS_SERVER\Administrator
                                            AD_DOMAIN\Domain Admins
                                            AD_DOMAIN\dom_grp1
               BUILTIN\Users                AD_DOMAIN\Domain Users
                                            AD_DOMAIN\dom_usr1
               CIFS_SERVER\g1               CIFS_SERVER\u1
6 entries were displayed.
