vserver cifs users-and-groups local-group show-members
PDF of this doc site
Creating your file...
Display local groups' members
The vserver cifs users-and-groups local-group show-members
command displays members of a local group. The members can be local or Active Directory users or groups.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If this parameter is specified, the command displays group members of local groups that match the specified Vserver name.
[-group-name <CIFS name>]
- Group Name-
If this parameter is specified, the command displays group members of local groups that match the specified group name.
[-member <CIFS name>,…]
- Member Name-
If this parameter is specified, the command displays group members that match the specified member name. The name can be that of a local user, Active Directory user, or Active Directory group.
The following example displays members of local groups associated with Vserver "vs1".
cluster1::> vserver cifs users-and-groups local-group show-members -vserver vs1 Vserver Group Name Members -------------- ---------------------------- ------------------------ vs1 BUILTIN\Administrators CIFS_SERVER\Administrator AD_DOMAIN\Domain Admins AD_DOMAIN\dom_grp1 BUILTIN\Users AD_DOMAIN\Domain Users AD_DOMAIN\dom_usr1 CIFS_SERVER\g1 CIFS_SERVER\u1 6 entries were displayed.
