vserver nvme show-host-priority
Display NVMe Host Priority Information
The vserver nvme show-host-priority command displays NVMe I/O queue count and NVMe I/O queue depth for each host priority level and node in the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Use this parameter to display the NVMe priority, NVMe I/O queue count, and NVMe I/O queue depth that match the cluster node that you specify.
 [-transport-protocol {fc-nvme|nvme-tcp}]- Transport Protocol-
Use this parameter to display the priority, NVMe I/O queue count, and NVMe I/O queue depth that match the transport protocol that you specify.
 [-priority {regular|high}]- Host Priority-
Use this parameter to display the NVMe I/O queue count, and NVMe I/O queue depth that match the priority that you specify.
 [-io-queue-count <integer>]- I/O Queue count-
Use this parameter to display the priorities, transport-protocol, and NVMe I/O queue depth on each node that match the NVMe I/O queue count that you specify.
 [-io-queue-depth <integer>]- I/O Queue Depths-
Use this parameter to display the priorities, transport-protocol, and NVMe I/O count on each node that match the NVMe I/O queue depth that you specify.
cluster-1::*> nvme show-host-priority
      (vserver nvme show-host-priority)
      Node                  Protocol  Priority I/O Queue Count I/O Queue Depth
      node1                 fc-nvme
                                      regular                4             32
                                      high                   6             32
                            nvme-tcp
                                      regular                2            128
                                      high                   4            128
      node2                 fc-nvme
                                      regular                4             32
                                      high                   6             32
                            nvme-tcp
                                      regular                2            128
                                      high                   4            128
      8 entries were displayed.
