vserver nvme show-host-priority
Display NVMe Host Priority Information
The vserver nvme show-host-priority command displays NVMe I/O queue count and NVMe I/O queue depth for each host priority level and node in the cluster.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Use this parameter to display the NVMe priority, NVMe I/O queue count, and NVMe I/O queue depth that match the cluster node that you specify.
- [-transport-protocol {fc-nvme|nvme-tcp}]- Transport Protocol
Use this parameter to display the priority, NVMe I/O queue count, and NVMe I/O queue depth that match the transport protocol that you specify.
- [-priority {regular|high}]- Host Priority
Use this parameter to display the NVMe I/O queue count, and NVMe I/O queue depth that match the priority that you specify.
- [-io-queue-count <integer>]- I/O Queue count
Use this parameter to display the priorities, transport-protocol, and NVMe I/O queue depth on each node that match the NVMe I/O queue count that you specify.
- [-io-queue-depth <integer>]- I/O Queue Depths
Use this parameter to display the priorities, transport-protocol, and NVMe I/O count on each node that match the NVMe I/O queue depth that you specify.
cluster-1::*> nvme show-host-priority
      (vserver nvme show-host-priority)
      Node                  Protocol  Priority I/O Queue Count I/O Queue Depth
      node1                 fc-nvme
                                      regular                4             32
                                      high                   6             32
                            nvme-tcp
                                      regular                2            128
                                      high                   4            128
      node2                 fc-nvme
                                      regular                4             32
                                      high                   6             32
                            nvme-tcp
                                      regular                2            128
                                      high                   4            128
      8 entries were displayed.
 PDFs
PDFs
