Command reference
statistics settings modify
Modify settings for the statistics commands
This command modifies the settings for all of the statistics commands.
[-display-rates {true|false}] - Display Rates (privilege: advanced)
Specifies whether the statistics commands display rate counters in rates/second. The default is true.
[-client-stats {enabled|disabled}] - Collect Per-Client Statistics (privilege: advanced)
Specifies whether statistics commands display per-client information. The default is disabled.
Note If you enable this setting, you might significantly impact system performance.
[-counter-display-units {B|KB|MB|GB}] - Counter Display Units (privilege: advanced)
Specifies display units for the counters. The default setting is MB.
[-display-count-exponent <integer>] - Display Count Exponent (privilege: advanced)
Specifies display exponent value for the counters representing counts. The default setting is 3 (thousand).
The following example sets the value of the -display-rates parameter to false :
cluster1::*> statistics settings modify -display-rates false
