Command reference
metrocluster node show
Display MetroCluster node configuration information
The metrocluster node show command displays configuration information for the nodes in the MetroCluster configuration.
{ [-fields <fieldname>,…​]
| [-partners ]
If this option is used the MetroCluster node partnership view will be displayed.
| [-instance ] }
[-dr-group-id <integer>] - DR Group ID
If this parameter is specified, all nodes belonging to the specified DR group are displayed.
[-cluster <Cluster name>] - Cluster Name
If this parameter is specified, all nodes belonging to the specified cluster are displayed.
[-node <Node name>] - Node Name
If this parameter is specified, the specified node is displayed.
[-ha-partner <Node name>] - HA Partner Name
If this parameter is specified, the node with the specified HA partner is displayed.
[-dr-cluster <Cluster name>] - DR Cluster Name
[-dr-partner <Node name>] - DR Partner Name
If this parameter is specified, the node with the specified DR partner is displayed.
[-dr-auxiliary <Node name>] - DR Auxiliary Name
If this parameter is specified, the node with the specified DR auxiliary partner is displayed.
[-node-uuid <UUID>] - Node UUID
If this parameter is specified, the node with the specified Uuid is displayed.
[-ha-partner-uuid <UUID>] - HA Partner UUID
If this parameter is specified, the nodes with the specified HA partner is displayed.
[-dr-partner-uuid <UUID>] - DR Partner UUID
[-dr-auxiliary-uuid <UUID>] - DR Auxiliary UUID
[-node-cluster-uuid <UUID>] - Node Cluster UUID
[-ha-partner-cluster-uuid <UUID>] - HA Partner Cluster UUID
If this parameter is specified, all nodes whose HA partner belong to the specified cluster are displayed.
[-dr-partner-cluster-uuid <UUID>] - DR Partner Cluster UUID
If this parameter is specified, all nodes whose DR partner belong to the specified cluster are displayed.
[-dr-auxiliary-cluster-uuid <UUID>] - DR Auxiliary Cluster UUID
If this parameter is specified, all nodes whose DR auxiliary partner belong to the specified cluster are displayed.
[-node-systemid <integer>] - Node System ID
If this parameter is specified, all nodes with the specified system ID are displayed.
[-ha-partner-systemid <integer>] - HA Partner System ID
If this parameter is specified, all nodes with an HA partner with the specified system ID are displayed.
[-dr-partner-systemid <integer>] - DR Partner System ID
If this parameter is specified, all nodes with a DR partner with the specified system ID are displayed.
[-dr-auxiliary-systemid <integer>] - DR Auxiliary System ID
If this parameter is specified, all nodes with a DR auxiliary partner with the specified system ID are displayed.
[-dr-mirroring-state <text>] - State of DR Mirroring Config
If this parameter is specified, all nodes with this field set to the specified value are displayed. This field specifies if the NVRAM mirroring to the DR partner is enabled through the metrocluster configure command. This field needs to be set to "enabled" for the DR mirroring to be active.
[-configuration-state <text>] - Configuration State of Node
[-additional-configuration-info <text>] - Additional Configuration Info
[-dr-operation-state <text>] - DR Operation State
[-dr-operation-time <integer>] - Time to Complete Operation (secs)
[-node-object-limit {on|off}] - Specifies if the Node Object Limits are Enforced
[-node-ha-partner <text>] - Node and its HA Partner
[-automatic-uso {true|false}] - Automatic USO (privilege: advanced)
[-mccip-node {true|false}] - MCC-IP Node (privilege: advanced)
[-is-encryption-enabled {true|false}] - Encryption Enabled
The following example shows the output of the command before the MetroCluster configuration is done:
clusA::> metrocluster node show
       DR                               Configuration  DR
       Group Cluster Node               State          Mirroring Mode
       -     clusA   clusA-01           ready to configure
                     clusA-02           ready to configure
                     clusA-03           ready to configure
                     clusA-04           ready to configure
       4 entries were displayed.
clusA::> metrocluster node show -partners
                              Node (HA Partner) DR Partner (DR Auxiliary)
       Cluster:                           clusA -
                                   clusA-01 (-) - (-)
                                   clusA-02 (-) - (-)
                                   clusA-03 (-) - (-)
                                   clusA-04 (-) - (-)
The following example shows the output of the command when some DR groups in the MetroCluster configuration are not yet configured:
       DR                               Configuration  DR
       -     clusA   clusA-03           ready to configure
       1     clusA   clusA-01           configured     enabled   normal
                     clusA-02           configured     enabled   normal
             clusB   clusB-01           configured     enabled   normal
                     clusB-02           configured     enabled   normal
       6 entries were displayed.
       Cluster:                           clusA -
                                   clusA-03 (-) - (-)
                                   clusA-04 (-) - (-)
       Cluster:                           clusA clusB
                            clusA-01 (clusA-02) clusB-01 (clusB-02)
                            clusA-02 (clusA-01) clusB-02 (clusB-01)
       Cluster:                           clusB clusA
                            clusB-01 (clusB-02) clusA-01 (clusA-02)
                            clusB-02 (clusB-01) clusA-02 (clusA-01)
The following example shows the output of the command after after all DR groups in the MetroCluster configuration are configured:
       DR                               Configuration  DR
       2     clusA   clusA-03           configured     enabled   normal
                     clusA-04           configured     enabled   normal
             clusB   clusB-03           configured     enabled   normal
                     clusB-04           configured     enabled   normal
       8 entries were displayed.
                            clusA-03 (clusA-04) clusB-03 (clusB-04)
                            clusA-04 (clusA-03) clusB-04 (clusB-03)
                            clusB-03 (clusB-04) clusA-03 (clusA-04)
                            clusB-04 (clusB-03) clusA-04 (clusA-03)
