metrocluster node show
Display MetroCluster node configuration information
The metrocluster node show command displays configuration information for the nodes in the MetroCluster configuration.
[-fields <fieldname>,…] -
If you specify the
[-partners ] -
If this option is used the MetroCluster node partnership view will be displayed.
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-dr-group-id <integer>]- DR Group ID-
If this parameter is specified, all nodes belonging to the specified DR group are displayed.
[-cluster <Cluster name>]- Cluster Name-
If this parameter is specified, all nodes belonging to the specified cluster are displayed.
[-node <Node name>]- Node Name-
If this parameter is specified, the specified node is displayed.
[-ha-partner <Node name>]- HA Partner Name-
If this parameter is specified, the node with the specified HA partner is displayed.
[-dr-cluster <Cluster name>]- DR Cluster Name-
[-dr-partner <Node name>]- DR Partner Name-
If this parameter is specified, the node with the specified DR partner is displayed.
[-dr-auxiliary <Node name>]- DR Auxiliary Name-
If this parameter is specified, the node with the specified DR auxiliary partner is displayed.
[-node-uuid <UUID>]- Node UUID-
If this parameter is specified, the node with the specified Uuid is displayed.
[-ha-partner-uuid <UUID>]- HA Partner UUID-
If this parameter is specified, the nodes with the specified HA partner is displayed.
[-dr-partner-uuid <UUID>]- DR Partner UUID-
[-dr-auxiliary-uuid <UUID>]- DR Auxiliary UUID-
[-node-cluster-uuid <UUID>]- Node Cluster UUID-
[-ha-partner-cluster-uuid <UUID>]- HA Partner Cluster UUID-
If this parameter is specified, all nodes whose HA partner belong to the specified cluster are displayed.
[-dr-partner-cluster-uuid <UUID>]- DR Partner Cluster UUID-
If this parameter is specified, all nodes whose DR partner belong to the specified cluster are displayed.
[-dr-auxiliary-cluster-uuid <UUID>]- DR Auxiliary Cluster UUID-
If this parameter is specified, all nodes whose DR auxiliary partner belong to the specified cluster are displayed.
[-node-systemid <integer>]- Node System ID-
If this parameter is specified, all nodes with the specified system ID are displayed.
[-ha-partner-systemid <integer>]- HA Partner System ID-
If this parameter is specified, all nodes with an HA partner with the specified system ID are displayed.
[-dr-partner-systemid <integer>]- DR Partner System ID-
If this parameter is specified, all nodes with a DR partner with the specified system ID are displayed.
[-dr-auxiliary-systemid <integer>]- DR Auxiliary System ID-
If this parameter is specified, all nodes with a DR auxiliary partner with the specified system ID are displayed.
[-dr-mirroring-state <text>]- State of DR Mirroring Config-
If this parameter is specified, all nodes with this field set to the specified value are displayed. This field specifies if the NVRAM mirroring to the DR partner is enabled through the metrocluster configure command. This field needs to be set to "enabled" for the DR mirroring to be active.
[-configuration-state <text>]- Configuration State of Node-
[-additional-configuration-info <text>]- Additional Configuration Info-
[-dr-operation-state <text>]- DR Operation State-
[-dr-operation-time <integer>]- Time to Complete Operation (secs)-
[-node-object-limit {on|off}]- Specifies if the Node Object Limits are Enforced-
[-node-ha-partner <text>]- Node and its HA Partner-
[-automatic-uso {true|false}]- Automatic USO (privilege: advanced)-
The following example shows the output of the command before the MetroCluster configuration is done:
clusA::> metrocluster node show
DR Configuration DR
Group Cluster Node State Mirroring Mode
- clusA clusA-01 ready to configure
clusA-02 ready to configure
clusA-03 ready to configure
clusA-04 ready to configure
4 entries were displayed.
clusA::> metrocluster node show -partners
Node (HA Partner) DR Partner (DR Auxiliary)
Cluster: clusA -
clusA-01 (-) - (-)
clusA-02 (-) - (-)
clusA-03 (-) - (-)
clusA-04 (-) - (-)
The following example shows the output of the command when some DR groups in the MetroCluster configuration are not yet configured:
DR Configuration DR
- clusA clusA-03 ready to configure
1 clusA clusA-01 configured enabled normal
clusA-02 configured enabled normal
clusB clusB-01 configured enabled normal
clusB-02 configured enabled normal
6 entries were displayed.
Cluster: clusA -
clusA-03 (-) - (-)
clusA-04 (-) - (-)
Cluster: clusA clusB
clusA-01 (clusA-02) clusB-01 (clusB-02)
clusA-02 (clusA-01) clusB-02 (clusB-01)
Cluster: clusB clusA
clusB-01 (clusB-02) clusA-01 (clusA-02)
clusB-02 (clusB-01) clusA-02 (clusA-01)
The following example shows the output of the command after after all DR groups in the MetroCluster configuration are configured:
DR Configuration DR
2 clusA clusA-03 configured enabled normal
clusA-04 configured enabled normal
clusB clusB-03 configured enabled normal
clusB-04 configured enabled normal
8 entries were displayed.
clusA-03 (clusA-04) clusB-03 (clusB-04)
clusA-04 (clusA-03) clusB-04 (clusB-03)
clusB-03 (clusB-04) clusA-03 (clusA-04)
clusB-04 (clusB-03) clusA-04 (clusA-03)
