Command reference
security login external-role-mapping delete
Delete a external role mapping
This command deletes an external role mapping.
-external-role <text> - External Role Name
This parameter specifies the name of the external role to be deleted.
-provider {basic|keycloak|auth0|adfs|entra} - Provider Type
The IDP (Identity Provider) type of the external role to be deleted.
This command deletes an external role mapping named 'Administrator' from the IDP 'entra'.
cluster1::> security login external-role-mapping delete -external-role Administrator -provider entra
