security anti-ransomware show
Display Anti-ransomware Package Version of the Node
The security anti-ransomware show command displays the Anti-ransomware version of a node.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name-
If this parameter is specified, the command displays the Anti-ransomware version of specified node.
[-version <text>]- Anti-Ransomware Version-
If this parameter is specified, the command displays node with the specified Anti-ransomware version.
The following example shows a sample output for this command:
C1_cluster::*> security anti-ransomware show-version Node Version -------------------- ---------------- sti221-vsim-sr049g 1.0 sti221-vsim-sr049h 1.0 2 entries were displayed.
