storage failover show
Display storage failover status
The storage failover show command displays information about storage-failover configurations. By default, the command displays the following information:
Node name.
Partner node name.
Whether storage failover is possible.
The current state of storage failover. If the takeover is disabled the appropriate reason would be displayed.
To display detailed information about storage failover on a specific node, run the command with the -node parameter. The detailed view adds the following information:
Node NVRAM ID.
Partner NVRAM ID.
Whether storage failover is enabled.
Whether the storage-failover interconnect is available.
Status of individual storage-failover interconnect links.
Type and vendor of the storage-failover interconnect.
Partner State
Status codes from the takeover-by-partner process. Possible values include:
NVRAM_DOWN
OPERATOR_DISABLE_NVRAM
PARTNER_RESET
FM_TAKEOVER
NVRAM_MISMATCH
OPERATOR_DENY
CLUSTER_DISABLE
VERSION
SHELF_HOT
REVERT_IN_PROGRESS
HALT_NOTKOVER
TAKEOVER_ON_PANIC
Reasons why takeover is not possible, if applicable. Possible values include:
NOT_INIT
DISABLED
DEGRADED
MBX_UNKNOWN
FM_VERSION
PARTNER_DISABLED
OPERATOR_DENY
NVRAM_MISMATCH
VERSION
IC_ERROR
BOOTING
SHELF_HOT
PARTNER_REVERT_IN_PROGRESS
LOCAL_REVERT_IN_PROGRESS
PARTNER_TAKEOVER
LOCAL_TAKEOVER
HALT_NOTKOVER
LOG_UNSYNC
UNKNOWN
WAITING_FOR_PARTNER
LOW_MEMORY
HALTING
MBX_UNCERTAIN
NO_AUTO_TKOVER
Time until takeover, in seconds.
Time until auto giveback, in seconds.
Delay for auto giveback, in seconds.
List of local mailbox disks.
List of partner mailbox disks.
Whether operator-initiated planned takeover will be optimized for performance by relocating SFO (non-root) aggregates serially to the partner prior to takeover.
You can specify additional parameters to select the displayed information. For example, to display information only about storage-failover configurations whose interconnect is down, run the command with` -interconnect-up false` .
[-fields <fieldname>,…] -
If you specify the
[-advanced ](privilege: advanced) -
Displays the following information:
Node name
Whether kill messages are issued during a takeover operation
Whether the node controls its partner's storage aggregates
The time when firmware notification was received
The time when booting notification was received
The time at which the last takeover or giveback operation occurred, in microseconds
The number of times the failover log was unsynchronized
[-iotime ](privilege: advanced) -
Node name
Primary normal I/O time
Primary transition I/O time
Backup normal I/O time
Backup transition I/O time
[-mailbox-status ](privilege: advanced) -
Node name
Primary mailbox status
Backup mailbox status
[-more-options ](privilege: advanced) -
Node name
Whether takeover on short uptime is enabled
Short uptime, in seconds
Number of giveback attempts
Interval of giveback attempts, in minutes
Whether the primary mailbox is online
Mailbox status read interval, in seconds
Mailbox status write interval, in seconds
[-options ] -
Node name
Whether automatic giveback operations are enabled
Whether long-running operations are terminated when an automatic giveback operation is initiated
Whether the node checks its partner's readiness before initiating a giveback operation
The time, in seconds, that the node remains unresponsive before its partner initiates a takeover operation
Whether the node automatically takes over for its partner if the partner fails
Whether the node automatically takes over for its partner if the partner panics
Whether the node automatically takes over for its partner if the partner reboots
whether Hardware Assisted Takeover is enabled
Ip address on which the partner node listens to the Hardware Assist alerts
Port number on which the partner node listens to the Hardware Assist alerts
If this parameter is specified when the privilege level is set to advanced or higher, the command displays the information in the previous list and the following additional information:
Whether the node takes over for its partner if its partner fails after a period of time, which is listed in the following field
The number of seconds before the node takes over for its partner
The number of times the node attempts an automatic giveback operation within a period of time
The number of minutes in which the automatic giveback attempts can occur
Whether storage-failover status is communicated via mailbox disks
The interval at which the node reads its partner node's status from the mailbox disks
The interval at which the node writes its status to the mailbox disks
The interval at which Hardware assist h/w sends a heartbeat
The number of times the Hardware assist alert is sent
[-progress ](privilege: advanced) -
Node name
Maximum resource-table index number
Current resource-table index number
Current resource-table entry
[-takeover-status ] -
Node name
Partner name
Takeover enabled
Takeover possible
Interconnect up
State
Node NVRAM ID
Partner NVRAM ID
Reason Takeover Not Possible By Partner
Time Until Takeover
[-timeout ](privilege: advanced) -
Node name
Fast timeout
Slow timeout
Mailbox timeout
Connection timeout
Operator timeout
Firmware timeout
Dump-core timeout
Booting timeout
Reboot timeout
[-transit ](privilege: advanced) -
Node name
Transit Timer Enabled
Transit Timeout
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the nodes whose name matches this parameter value.
[-partner-name <text>]- Partner Name-
Selects the nodes that have the specified partner-name setting.
[-nvramid <integer>]- Node NVRAM ID-
Selects the nodes that have the specified NVRAM ID setting.
[-partner-nvramid <integer>]- Partner NVRAM ID-
Selects the nodes that have the specified partner NVRAM ID setting.
[-enabled {true|false}]- Takeover Enabled-
Selects the nodes that have the specified enabled setting.
[-mode {ha|non_ha}]- HA Mode-
Selects the nodes that have the specified HA-mode setting. If the value is set to
hathen the node is a member of a storage-failover configuration. If it is set tonon-hathen it is in a stand alone configuration. [-possible {true|false}]- Takeover Possible-
Selects the nodes that have the specified failover-possible setting.
[-reason <text>,…]- Reason Takeover not Possible-
Selects the nodes that have the specified reason-not-possible setting. Possible values include:
NOT_INIT
DISABLED
DEGRADED
MBX_UNKNOWN
FM_VERSION
PARTNER_DISABLED
OPERATOR_DENY
NVRAM_MISMATCH
VERSION
IC_ERROR
BOOTING
SHELF_HOT
PARTNER_TAKEOVER
LOCAL_TAKEOVER
HALT_NOTKOVER
LOG_UNSYNC
UNKNOWN
WAITING_FOR_PARTNER
LOW_MEMORY
HALTING
MBX_UNCERTAIN
NO_AUTO_TKOVER
[-interconnect-up {true|false}]- Interconnect Up-
Selects the nodes that have the specified interconnect-up setting.
[-interconnect-links <text>]- Interconnect Links-
Selects the nodes that have the specified interconnect-links setting.
[-interconnect-type <text>]- Interconnect Type-
Selects the nodes that have the specified interconnect-type setting.
[-state-description <text>]- State Description-
Selects the nodes that have the specified state-description setting.
[-partner-state <text>]- Partner State-
Selects the nodes that have the specified partner-state setting. Possible values include:
OPERATOR COMPLETED
DEBUGGUER COMPLETED
PROGRESS COUNTER
I/O ERROR
BAD CHECKSUM
RESERVED
UNKNOWN
INITIALIZING
IN POWER-ON SELF TEST
BOOTING
BOOT FAILED
WAITING
KERNEL LOADED
UP
IN DEBUGGER
WAITING FOR OPERATOR INPUT
DUMPING CORE
HALTED
REBOOTING
WAITING FOR GIVEBACK (DISK RESERVATIONS)
WAITING FOR GIVEBACK (HA MAILBOXES)
DUMPING SPARECORE
MULTI-DISK PANIC
IN TAKEOVER
[-time-until-takeover <integer>]- Time Until Takeover-
Selects the nodes that have the specified time-until-takeover setting.
[-partner-reason <text>,…]- Reason Takeover not Possible by Partner-
Selects the nodes that have the specified partner-reason text setting.
[-killpackets {true|false}]- Issue Kill Packets (privilege: advanced)-
Selects the nodes that have the specified kill packets setting.
[-partner-aggregates {true|false}]- Control Partner Aggregates (privilege: advanced)-
Selects the nodes that have the specified partner aggregates setting.
[-current-index <integer>]- Current Progress Index (privilege: advanced)-
Selects the nodes that have the specified current-progress index setting.
[-current-entry <text>]- Current Progress Entry (privilege: advanced)-
Selects the nodes that have the specified current-progress entry setting.
[-maximum-index <integer>]- Maximum Progress Index (privilege: advanced)-
Selects the nodes that have the specified maximum-progress index setting.
[-pmbox-status <text>,…]- Primary Mailbox Status (privilege: advanced)-
Selects the nodes that have the specified primary mailbox status setting. Possible values include:
MBX_STATUS_NODISKS
MBX_STATUS_UNCERTAIN
MBX_STATUS_STALE
MBX_STATUS_CONFLICTED
MBX_STATUS_OLD_VERSION
MBX_STATUS_NOT_FOUND
MBX_STATUS_WRONG_STATE
MBX_STATUS_BACKUP
[-bmbox-status <text>,…]- Backup Mailbox Status (privilege: advanced)-
Selects the nodes that have the specified backup-mailbox status setting. See the description of the
-pmbox-statusparameter for a list of possible values. [-major-seq-num-local <integer>]- Local Major Sequence Number (privilege: advanced)-
Selects the nodes that have the specified mailbox heartbeat major sequence number on the local node.
[-minor-seq-num-local <integer>]- Local Minor Sequence Number (privilege: advanced)-
Selects the nodes that have the specified mailbox heartbeat minor sequence number on the local node.
[-major-seq-num-partner <integer>]- Partner Major Sequence Number (privilege: advanced)-
Selects the nodes that have the specified mailbox heartbeat major sequence number on the partner node.
[-minor-seq-num-partner <integer>]- Partner Minor Sequence Number (privilege: advanced)-
Selects the nodes that have the specified mailbox heartbeat minor sequence number on the partner node.
[-local-mbx-node-status <Mailbox Status>]- Local Mailbox Node Status (privilege: advanced)-
Selects the nodes that have the specified local mailbox node status. Possible values include:
MBX_UNKNOWN - Local node is up, mailbox uninitialized
MBX_TAKEOVER_DISABLED - Local node is up but takeover is disallowed
MBX_TAKEOVER_ENABLED - Local node is up and takeover is allowed
MBX_TAKEOVER_ACTIVE - Partner node has taken over
MBX_GIVEBACK_DONE - Giveback completed, but local node has not yet restarted
[-mbx-abs-time-local <integer>]- Local Mailbox Absolute Time (privilege: advanced)-
Selects the nodes that have the specified local mailbox channel absolute time. This time is measured in msecs since 1/1/1970 (epoch).
[-mbx-sk-time-local <integer>]- Local Mailbox Kernel Time (privilege: advanced)-
Selects the nodes that have the specified local mailbox channel Kernel Time.
[-mbx-sk-cycles-local <integer>]- Local Mailbox CPU Cycles (privilege: advanced)-
Selects the nodes that have the specified local mailbox channel CPU Cycle count.
[-ic-abs-time-local <integer>]- Local IC Absolute Time (privilege: advanced)-
Selects the nodes that have the specified local Interconnect channel absolute time. This time is measured in msecs since 1/1/1970 (epoch).
[-ic-sk-time-local <integer>]- Local IC Kernel Time (privilege: advanced)-
Selects the nodes that have the specified local Interconnect channel Kernel Time.
[-ic-sk-cycles-local <integer>]- Local IC CPU Cycles (privilege: advanced)-
Selects the nodes that have the specified local Interconnect channel CPU Cycle count.
[-partner-mbx-node-status <Mailbox Status>]- Partner Mailbox Node Status (privilege: advanced)-
Selects the nodes that have the specified partner mailbox node status. Possible values include:
MBX_UNKNOWN
MBX_TAKEOVER_ACTIVE
MBX_GIVEBACK_DONE
[-mbx-abs-time-partner <integer>]- Partner Mailbox Absolute Time (privilege: advanced)-
Selects the nodes that have the specified partner mailbox channel absolute time. This time is measured in msecs since 1/1/1970 (epoch).
[-mbx-sk-time-partner <integer>]- Partner Mailbox Kernel Time (privilege: advanced)-
Selects the nodes that have the specified partner mailbox channel Kernel Time.
[-mbx-sk-cycles-partner <integer>]- Partner Mailbox CPU Cycles (privilege: advanced)-
Selects the nodes that have the specified partner mailbox channel CPU Cycle count.
[-mbx-major-seq-num-partner <integer>]- Partner Mailbox Major Sequence Number (privilege: advanced)-
Selects the nodes that have the specified partner mailbox channel major sequence number.
[-mbx-minor-seq-num-partner <integer>]- Partner Mailbox Minor Sequence Number (privilege: advanced)-
Selects the nodes that have the specified partner mailbox channel minor sequence number.
[-ic-abs-time-partner <integer>]- Partner IC Absolute Time (privilege: advanced)-
Selects the nodes that have the specified partner Interconnect channel absolute time. This time is measured in msecs since 1/1/1970 (epoch).
[-ic-sk-time-partner <integer>]- Partner IC Kernel Time (privilege: advanced)-
Selects the nodes that have the specified partner Interconnect channel Kernel Time.
[-ic-sk-cycles-partner <integer>]- Partner IC CPU Cycles (privilege: advanced)-
Selects the nodes that have the specified partner Interconnect channel CPU Cycle count.
[-ic-major-seq-num-partner <integer>]- Partner IC Major Sequence Number (privilege: advanced)-
Selects the nodes that have the specified partner Interconnect channel major sequence number.
[-ic-minor-seq-num-partner <integer>]- Partner IC Minor Sequence Number (privilege: advanced)-
Selects the nodes that have the specified partner Interconnect channel minor sequence number.
[-local-takeover-info <text>]- Local Takeover Info (privilege: advanced)-
Selects the nodes that have the specified local node takeover information. This includes the type of negotiated failover request, or if takeover is not possible, the reason why takeover is disabled. Possible values include:
NOTKOVER_NVRAM_DOWN - NVRAM mirror is down
NOTKOVER_OPERATOR_DISABLE_NVRAM - Operator disabled
NOTKOVER_PARTNER_RESET - A link reset is in progress
NOTKOVER_FM_TAKEOVER - The failover monitor has declared takeover
NOTKOVER_NVRAM_MISMATCH - NVRAM sizes mismatch
NOTKOVER_OPERATOR_DENY - Operator denies takeover
NOTKOVER_CLUSTER_DISABLE - Cluster is disabled
NOTKOVER_VERSION - Version mismatch
NOTKOVER_SHELF_HOT - Disk shelf is too hot
NOTKOVER_REVERT_IN_PROGRESS - Revert is in progress
NOTKOVER_HALT_NOTKOVER - Node halted in no-takeover mode
TKOVER_ON_REBOOT - Enable takeover on reboot
TKOVER_ON_PANIC - Enabled takeover on panic
TKOVER_ON_STUTTER_DISABLED - Disable takeover on short uptime
NFO_DISK_SHELF_ENABLED - Negotiated failover for disk shelf module is enabled
NFO_ISCSI_ENABLED - Negotiated failover for network interfaces module is enabled
NFO_FCP_TARGET_ENABLED - Negotiated failover for fcp target module is enabled
[-partner-takeover-info <text>]- Partner Takeover Info (privilege: advanced)-
Selects the nodes that have the specified partner node takeover information. This includes the type of negotiated failover request, or if takeover is not possible, the reason why takeover is disabled. Possible values include:
TKOVER_ON_REBOOT - Takeover on reboot is enabled
TKOVER_ON_PANIC - Takeover on panic is enabled
[-local-headswap-state <Headswap State>]- Local Head Swap State (privilege: advanced)-
Selects the nodes that have the specified local node headswap state. Possible values are:
HEADSWAP_NONE - head swap not in progress
HEADSWAP_START - head swap started
HEADSWAP_CFO_START - CFO phase of head swap started
HEADSWAP_CFO_END - CFO phase of head swap completed
HEADSWAP_SFO_START - SFO phase of head swap started
[-partner-headswap-state <Headswap State>]- Partner Head Swap State (privilege: advanced)-
Selects the nodes that have the specified partner node headswap state. Possible values are:
[-fast-timeout <integer>]- Fast Timeout (privilege: advanced)-
Selects the nodes that have the specified fast-timeout configuration setting.
[-slow-timeout <integer>]- Slow Timeout (privilege: advanced)-
Selects the nodes that have the specified slow-timeout setting.
[-mailbox-timeout <integer>]- Mailbox Timeout (privilege: advanced)-
Selects the nodes that have the specified mailbox-timeout setting.
[-connect-timeout <integer>]- Connect Timeout (privilege: advanced)-
Selects the nodes that have the specified connect-timeout setting.
[-operator-timeout <integer>]- Operator Timeout (privilege: advanced)-
Selects the nodes that have the specified operator-timeout setting.
[-firmware-timeout <integer>]- Firmware Timeout (privilege: advanced)-
Selects the nodes that have the specified firmware-timeout setting.
[-dumpcore-timeout <integer>]- Dumpcore Timeout (privilege: advanced)-
Selects the nodes that have the specified dump-core timeout setting.
[-booting-timeout <integer>]- Booting Timeout (privilege: advanced)-
Selects the nodes that have the specified booting-timeout setting.
[-transit-timer {true|false}]- Transit Timer Enabled (privilege: advanced)-
Selects the nodes that have the specified transit-timer setting.
[-transit-timeout <integer>]- Transit Timeout (privilege: advanced)-
Selects the nodes that have the specified transit timeout.
[-firmware-received <integer>]- Firmware Received (privilege: advanced)-
Selects the nodes that have the specified firmware-reception time.
[-firmware-received-cycles <integer>]- Firmware Received in CPU Cycles (privilege: advanced)-
Selects the nodes that have the specified firmware-reception time in CPU Cycles.
[-booting-received <integer>]- Booting Received (privilege: advanced)-
Selects the nodes that have the specified booting-reception time.
[-transit-time <integer>]- Transit Event Time (privilege: advanced)-
Selects the nodes whose last failover event occurred at the specified time.
[-pnormal <integer>]- Primary Normal IO Time (privilege: advanced)-
Selects the nodes that have the specified normal primary-mailbox I/O time.
[-ptransition <integer>]- Primary Transition IO Time (privilege: advanced)-
Selects the nodes that have the specified transitional primary-mailbox I/O time.
[-bnormal <integer>]- Backup Normal IO Time (privilege: advanced)-
Selects the nodes that have the specified normal backup-mailbox I/O time.
[-btransition <integer>]- Backup Transition IO Time (privilege: advanced)-
Selects the nodes that have the specified transitional backup-mailbox I/O time.
[-logs-unsynced <integer>]- Logs Unsynced Count (privilege: advanced)-
Selects the nodes that have the specified count of unsynchronized logs.
[-auto-giveback {true|false}]- Auto Giveback Enabled-
Selects the nodes that have the specified auto-giveback setting.
[-detection-time <integer>]- Takeover Detection Time (secs)-
Selects the nodes that have the specified detection-time setting.
[-onfailure {true|false}]- Takeover on Failure Enabled-
Selects the nodes that have the specified takeover-on-failure setting.
[-onpanic {true|false}]- Takeover on Panic Enabled-
Selects the nodes that have the specified takeover-on-panic setting.
[-onshort-uptime {true|false}]- Takeover on Short Uptime Enabled (privilege: advanced)-
Selects the storage-failover configurations that match this parameter value.
[-short-uptime <integer>]- Short Uptime (secs) (privilege: advanced)-
Selects the nodes that have the specified short-uptime value.
[-attempts <integer>]- Number of Giveback Attempts (privilege: advanced)-
Selects the nodes that have the specified number of giveback attempts.
[-attempts-time <integer>]- Giveback Attempts Period (minutes) (privilege: advanced)-
Selects the nodes that have the specified time setting for giveback attempts.
[-propagate {true|false}]- Propagate Status via Mailbox (privilege: advanced)-
Selects the nodes that have the specified propagate-status-via-mailbox setting.
[-read-interval <integer>]- Node Status Read Interval (secs) (privilege: advanced)-
Selects the nodes that have the specified read interval.
[-write-interval <integer>]- Node Status Write Interval (secs) (privilege: advanced)-
Selects the nodes that have the specified write interval.
[-onreboot {true|false}]- Takeover on Reboot Enabled-
Selects the nodes that have the specified takeover-on-reboot setting.
[-delay-seconds <integer>]- Delay Before Auto Giveback (secs)-
Selects the nodes that have the specified delay (in seconds) for the auto giveback.
[-hwassist {true|false}]- Hardware Assist Enabled-
Selects the nodes that have the specified hwassist setting.
[-hwassist-partner-ip <IP Address>]- Partner's Hwassist IP-
Selects the nodes that have the specified hwassist-partner-ip setting.
[-hwassist-partner-port <integer>]- Partner's Hwassist Port-
Selects the nodes that have the specified hwassist-partner-port setting.
[-hwassist-health-check-interval <integer>]- Hwassist Health Check Interval (secs)-
Selects the nodes that have the specified hwassist health check interval, in seconds.
[-hwassist-retry-count <integer>]- Hwassist Retry Count-
Selects the nodes that have the specified hwassist retry count, in seconds.
[-hwassist-status <text>]- Hwassist Status-
Selects the nodes that have the specified hwassist-status setting.
[-time-until-autogiveback <integer>]- Time Until Auto Giveback (secs)-
Selects the nodes that have the specified time(in seconds) until auto giveback.
[-local-mailbox-disks <text>]- Local Mailbox Disks-
Selects the nodes that have the specified mailbox disks on the local node.
[-partner-mailbox-disks <text>]- Partner Mailbox Disks-
Selects the nodes that have the specified mailbox disks on the partner node.
[-local-firmware-state <text>]- Local Firmware State (privilege: advanced)-
Selects the nodes that have the specified firmware state on the local node.
[-local-firmware-progress <integer>]- Local Firmware Progress Counter (privilege: advanced)-
Selects the nodes that have the specified firmware progress counter for the local node.
[-partner-firmware-state <text>]- Partner Firmware State (privilege: advanced)-
Selects the nodes that have the specified firmware state of the partner node.
[-partner-firmware-progress <integer>]- Partner Firmware Progress Counter (privilege: advanced)-
Selects the nodes that have the specified firmware progress counter for the partner node.
[-local-missing-disks <text>]- Missing Disks on Local Node-
Selects the nodes that have the specified missing disks on the local node.
[-partner-missing-disks <text>]- Missing Disks on Partner Node-
Selects the nodes that have the specified missing disks on the partner node.
[-reboot-timeout <integer>]- Reboot Timeout (privilege: advanced)-
Selects the nodes that have the specified reboot timeout.
[-time-since-takeover <text>]- Time Since Takeover-
Selects the nodes that have been in takeover mode for the specified amount of time.
[-auto-giveback-after-panic {true|false}]- Auto Giveback After Takeover On Panic-
Selects the nodes that have the specified auto-giveback-after-panic setting. If
truethen an automatic giveback operation is invoked when the failover node of an HA pair is repaired and rebooted. The takeover node of the HA pair detects this and initiates a giveback operation automatically. [-is-giveback-requested {true|false}]- Giveback Requested (privilege: advanced)-
Selects the nodes that have the specified is-giveback-requested setting. If
true, a deferred giveback request has been made by the local node. [-auto-giveback-last-veto-check <integer>]- Auto Giveback Last Veto Check (privilege: advanced)-
Selects the nodes that have the specified auto-giveback-last-veto-check time. This setting indicates the time, in milliseconds, when the local node made the most recent giveback veto check.
[-is-auto-giveback-attempts-exceeded {true|false}]- Auto Giveback Attempts Exceeded (privilege: advanced)-
Selects the nodes that have the specified is-auto-giveback-attempts-exceeded setting. If
true, the local node has exceeded the maximum number of allowed auto giveback attempts. [-was-auto-giveback-done {true|false}]- Was Auto Giveback Done (privilege: advanced)-
Selects the nodes that have the specified was-auto-giveback-done setting. If
true, the last giveback was automatic (as opposed to a manual giveback). [-is-cifs-auto-giveback-stopping {true|false}]- Is CIFS Auto Giveback Stopping (privilege: advanced)-
Selects the nodes that have the specified is-cifs-auto-giveback-stopping setting. If
true, the local node has initiated CIFS termination as part of an automatic giveback. [-aggregate-migration-timeout <integer>]- Aggregate Migration Timeout (secs) (privilege: advanced)-
Selects the nodes that have the specified aggregate migration timeout.
[-is-mirror-enabled {true|false}]- Is NVRAM Mirroring Enabled (privilege: advanced)-
Selects the nodes that have the specified is-mirror-enabled setting. If
true, then NVRAM mirroring is enabled. [-is-mirror-consistency-required {true|false}]- Is Mirror Consistency Required (privilege: advanced)-
Selects the nodes that have the specified is-mirror-consistency-required setting. If
true, then NVRAM mirror consistency is required. [-is-memory-insufficient {true|false}]- Is Memory Insufficient To Takeover (privilege: advanced)-
Selects the nodes that have the specified is-memory-insufficient setting. If
true, the local node does not have enough memory to perform a takeover. [-memio-state <memio status>]- Current State of Memio Link (privilege: advanced)-
Selects the nodes that have the specified memio layer link current state. Possible values are:
UNINIT - Uninitialized
CLOSED - Closed
HB_LISTEN - Listening for connect
SYN_SENT - Sent generation information
ESTABLISHED - Connection established
[-is-degraded {true|false}]- Are Partner Mailbox Disks Not Known (privilege: advanced)-
Selects the nodes that have the specified is-degraded setting. If
true, takeovers are deferred because partner mailbox disks are not known. [-reserve-policy <reserve policy>]- FM Reservation Policy (privilege: advanced)-
Selects the nodes that have the specified disk reservation policy. Possible values are:
RESERVE_NO_DISKS - no disk reservations made during takeover, nor are disk reservations released during giveback
RESERVE_ALWAYS_AFTER_TAKEOVER - reservations are issued at at takeover. When disks are subsequently added, they are also reserved. All disks are released at giveback
[-reset-disks {true|false}]- Issue Disk Resets during Failover (privilege: advanced)-
Selects the nodes that have the specified reset-disks setting. If
true, disks are reset during takeover/giveback. [-total-system-uptime <integer>]- Total System Uptime (privilege: advanced)-
Selects the nodes that have the specified total system uptime, in milliseconds.
[-current-time <integer>]- Current System Time (privilege: advanced)-
Selects the nodes that have the specified current time on the node.
[-fm-takeover-state <FM Takeover/Giveback Transition>]- FM Takeover State (privilege: advanced)-
Selects the nodes that have the specified takeover state. Possible values are:
FT_NONE - Not in takeover
FT_TAKEOVER_STARTED - Local node has initiated takeover
FT_TAKEOVER_COMMITTED - Takeover has been committed
FT_TAKEOVER_DONE_OK - Local node successfully completed takeover
FT_TAKEOVER_DONE_FAILED - Takeover failed
[-fm-giveback-state <FM Takeover/Giveback Transition>]- FM Giveback State (privilege: advanced)-
Selects the nodes that have the specified giveback state. Possible values are:
FT_NONE - Not in giveback
FT_GIVEBACK_READY - Partner node is ready for giveback
FT_GIVEBACK_STARTED - Local node has initiated giveback
FT_GIVEBACK_COMMITTED - Giveback has been committed
FT_GIVEBACK_DONE_OK - Giveback completed successfully
[-takeover-reason <FM Takeover Reason>]- Reason why takeover triggered (privilege: advanced)-
Selects the nodes that have the specified takeover reason. Possible values are:
TAKEOVER_NONE - Not in takeover
TAKEOVER_IMMEDIATE - Operator initiated forced takeover
TAKEOVER_NDU - Takeover initiated as part of NDU
TAKEOVER_FORCED - Operator initiated forced takeover, possible data loss
TAKEOVER_EARLY - Takeover occurred during the boot process
TAKEOVER_OPERATOR_EXP - Takeover occurred after the operator timeout expired
TAKEOVER_POST_FAILED - Takeover occurred on POST failure
TAKEOVER_PANIC - Takeover on panic
TAKEOVER_SHORTUPTIME - Takeover after rapid toggling between up and down states
TAKEOVER_SPARECORE_EXP - Takeover on panic timeout expiration
TAKEOVER_REBOOT_EXP - Takeover on reboot timer expiration
TAKEOVER_BOOTING_EXP - Takeover on booting timer expiration
TAKEOVER_FIRMWARE_EXP - Takeover on firmware timer expiration
TAKEOVER_NFO_SHUTDOWN - Takeover on negotiated failover shutdown
TAKEOVER_NFO_TIMER - Takeover on negotiated failover timer expiration
TAKEOVER_MDP - Takeover on multi-disk panic
TAKEOVER_REBOOT - Takeover on reboot
TAKEOVER_HALT - Takeover on halt
TAKEOVER_CLAM - CLAM-triggered takeover
TAKEOVER_HWASSIST - Hardware-assisted takeover
TAKEOVER_NORMAL - Operator initiated takeover
[-ha-type {none|shared_storage|non_shared_storage}]- HA Type-
If this parameter is specified, the command selects the nodes that have the specified HA-type setting. If the value is set to
shared_storage, then the node is in a storage-failover configuration using the shared storage. If it is set tonon_shared_storage, then the node is in a storage-failover configuration using the unshared storage. If it is set tonone, then the node is not part of a storage-failover configuration.
The following example displays information about all storage-failover configurations:
cluster1::> storage failover show
Takeover
Node Partner Possible State
node0 node1 true Connected to node1
node2 node3 true Connected to node3
node1 node0 true Connected to node0
node3 node2 true Connected to node2
4 entries were displayed.
