Command reference
vserver nfs pnfs devices delete
Delete a pNFS device
The vserver nfs pnfs devices delete command deletes a unique pNFS device. The pNFS device to be deleted is identified by the unique device mapping identifier (mid) parameter passed to this operation. When this operation is successful, the device mappings corresponding to the device and the information corresponding to the device itself are removed. You can obtain the global mapping identifier from the list of devices using the command vserver nfs pnfs devices show .
-global-device-table-id <integer> - Global Device Mapping Table ID (privilege: advanced)
This parameter specifies the pNFS global device mapping identifier that uniquely identifies a pNFS device
The following example deletes the device information of a device with global mapping identifier value 2.
cluster1::> vserver nfs pnfs delete -mid 2
