Command reference
system controller bezel-led modify
Modify the state of the bezel LED log (lit or unlit)
The system controller bezel-led modify command controls the illumination state of the LED logo on the chassis bezel (lit or unlit) of a node. On platforms where two controllers in a high-availability (HA) configuration share the same chassis, any changes to the LED logo's illumination state are kept synchronized on both nodes.
-node {<nodename>|local} - Node
The node whose bezel LED logo illumination state is being modified.
[-state {off|on|disconnected|bezel-switch|unknown}] - Bezel LED Logo State
The bezel LED logo illumination state of the node. The possible values are: on (lit), off (unlit),bezel-switch or disconnected. The default state is on .
The following example turns on the bezel LED logo:
cluster1::> system controller bezel-led modify -node node1 -state on
The following example turns off the bezel LED logo:
cluster1::> system controller bezel-led modify -node node1 -state off
The following example lets the bezel switch control the bezel LED:
cluster1::> system controller bezel-led modify -node node1 -state bezel-switch
