security config modify
Modify Security Configuration Options
The security config modify command modifies the existing cluster-wide security configuration. If you enable FIPS-compliant mode, the cluster will automatically select only compliant TLS protocols (currently TLSv1.3 and TLSv1.2). Non-compliant protocols are not enabled when FIPS-compliant mode is disabled. Use the -supported-protocols parameter to include or exclude TLS protocols independently from the FIPS mode. All protocols at or above the lowest version specified will be enabled, even those not explicitly specified. By default, FIPS mode is disabled, and ONTAP supports the TLSv1.3 and TLSv1.2 protocols. For backward compatibility, ONTAP supports adding SSLv3 and TLSv1 to the supported-protocols list when FIPS mode is disabled. Use the -supported-cipher-suites parameter to control which TLS cipher suites are permitted by the system. By default the supported-cipher-suites setting is TLS_RSA_WITH_AES_128_CCM, TLS_RSA_WITH_AES_128_CCM_8, TLS_RSA_WITH_AES_128_GCM_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_128_CBC_SHA256, TLS_RSA_WITH_AES_256_CCM, TLS_RSA_WITH_AES_256_CCM_8, TLS_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_256_CBC_SHA, TLS_RSA_WITH_AES_256_CBC_SHA256, TLS_RSA_WITH_ARIA_128_GCM_SHA256, TLS_RSA_WITH_ARIA_256_GCM_SHA384, TLS_RSA_WITH_CAMELLIA_128_CBC_SHA, TLS_RSA_WITH_CAMELLIA_128_CBC_SHA256, TLS_RSA_WITH_CAMELLIA_256_CBC_SHA, TLS_RSA_WITH_CAMELLIA_256_CBC_SHA256, TLS_DHE_DSS_WITH_AES_128_GCM_SHA256, TLS_DHE_DSS_WITH_AES_128_CBC_SHA, TLS_DHE_DSS_WITH_AES_128_CBC_SHA256, TLS_DHE_DSS_WITH_AES_256_GCM_SHA384, TLS_DHE_DSS_WITH_AES_256_CBC_SHA, TLS_DHE_DSS_WITH_AES_256_CBC_SHA256, TLS_DHE_DSS_WITH_ARIA_128_GCM_SHA256, TLS_DHE_DSS_WITH_ARIA_256_GCM_SHA384, TLS_DHE_DSS_WITH_CAMELLIA_128_CBC_SHA, TLS_DHE_DSS_WITH_CAMELLIA_128_CBC_SHA256, TLS_DHE_DSS_WITH_CAMELLIA_256_CBC_SHA, TLS_DHE_DSS_WITH_CAMELLIA_256_CBC_SHA256, TLS_DHE_PSK_WITH_AES_128_CBC_SHA, TLS_DHE_PSK_WITH_AES_128_CBC_SHA256, TLS_DHE_PSK_WITH_AES_128_CCM, TLS_PSK_DHE_WITH_AES_128_CCM_8, TLS_DHE_PSK_WITH_AES_128_GCM_SHA256, TLS_DHE_PSK_WITH_AES_256_CBC_SHA, TLS_DHE_PSK_WITH_AES_256_CBC_SHA384, TLS_DHE_PSK_WITH_AES_256_CCM, TLS_PSK_DHE_WITH_AES_256_CCM_8, TLS_DHE_PSK_WITH_AES_256_GCM_SHA384, TLS_DHE_PSK_WITH_ARIA_128_GCM_SHA256, TLS_DHE_PSK_WITH_ARIA_256_GCM_SHA384, TLS_DHE_PSK_WITH_CAMELLIA_128_CBC_SHA256, TLS_DHE_PSK_WITH_CAMELLIA_256_CBC_SHA384, TLS_DHE_PSK_WITH_CHACHA20_POLY1305_SHA256, TLS_DHE_RSA_WITH_AES_128_CCM, TLS_DHE_RSA_WITH_AES_128_CCM_8, TLS_DHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_256_CCM, TLS_DHE_RSA_WITH_AES_256_CCM_8, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_RSA_WITH_ARIA_128_GCM_SHA256, TLS_DHE_RSA_WITH_ARIA_256_GCM_SHA384, TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA, TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA256, TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA, TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA256, TLS_DHE_RSA_WITH_CHACHA20_POLY1305_SHA256, TLS_ECDHE_RSA_WITH_ARIA_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_ARIA_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_CCM, TLS_ECDHE_ECDSA_WITH_AES_128_CCM_8, TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_AES_256_CCM, TLS_ECDHE_ECDSA_WITH_AES_256_CCM_8, TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_ECDSA_WITH_ARIA_128_GCM_SHA256, TLS_ECDHE_ECDSA_WITH_ARIA_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_CBC_SHA256, TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_CBC_SHA384, TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256, TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA, TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA256, TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA, TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA384, TLS_ECDHE_PSK_WITH_CAMELLIA_128_CBC_SHA256, TLS_ECDHE_PSK_WITH_CAMELLIA_256_CBC_SHA384, TLS_ECDHE_PSK_WITH_CHACHA20_POLY1305_SHA256, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_CAMELLIA_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_CAMELLIA_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256, TLS_PSK_WITH_AES_128_CBC_SHA, TLS_PSK_WITH_AES_128_CBC_SHA256, TLS_PSK_WITH_AES_128_CCM, TLS_PSK_WITH_AES_128_CCM_8, TLS_PSK_WITH_AES_128_GCM_SHA256, TLS_PSK_WITH_AES_256_CBC_SHA, TLS_PSK_WITH_AES_256_CBC_SHA384, TLS_PSK_WITH_AES_256_CCM, TLS_PSK_WITH_AES_256_CCM_8, TLS_PSK_WITH_AES_256_GCM_SHA384, TLS_PSK_WITH_ARIA_128_GCM_SHA256, TLS_PSK_WITH_ARIA_256_GCM_SHA384, TLS_PSK_WITH_CAMELLIA_128_CBC_SHA256, TLS_PSK_WITH_CAMELLIA_256_CBC_SHA384, TLS_PSK_WITH_CHACHA20_POLY1305_SHA256, TLS_RSA_PSK_WITH_AES_128_CBC_SHA, TLS_RSA_PSK_WITH_AES_128_CBC_SHA256, TLS_RSA_PSK_WITH_AES_128_GCM_SHA256, TLS_RSA_PSK_WITH_AES_256_CBC_SHA, TLS_RSA_PSK_WITH_AES_256_CBC_SHA384, TLS_RSA_PSK_WITH_AES_256_GCM_SHA384, TLS_RSA_PSK_WITH_ARIA_128_GCM_SHA256, TLS_RSA_PSK_WITH_ARIA_256_GCM_SHA384, TLS_RSA_PSK_WITH_CAMELLIA_128_CBC_SHA256, TLS_RSA_PSK_WITH_CAMELLIA_256_CBC_SHA384, TLS_RSA_PSK_WITH_CHACHA20_POLY1305_SHA256, TLS_SRP_SHA_WITH_AES_128_CBC_SHA, TLS_SRP_SHA_WITH_AES_256_CBC_SHA, TLS_SRP_SHA_DSS_WITH_AES_128_CBC_SHA, TLS_SRP_SHA_DSS_WITH_AES_256_CBC_SHA, TLS_SRP_SHA_RSA_WITH_AES_128_CBC_SHA, TLS_SRP_SHA_RSA_WITH_AES_256_CBC_SHA, TLS_AES_128_GCM_SHA256, TLS_AES_256_GCM_SHA384, TLS_CHACHA20_POLY1305_SHA256 . Select a cipher suite which is available with the corresponding selected protocol. An invalid configuration may cause some functionality to fail to operate properly. Valid values for supported-cipher-suites are listed at "https://www.iana.org/assignments/tls-parameters/tls-parameters.xhtml" published by IANA.
-interface <SSL>- (DEPRECATED)-FIPS-Compliant Interface (privilege: advanced)-
This parameter has been deprecated in ONTAP 9.8 and may be removed in a future release of ONTAP. Selects the FIPS-compliant interface. The only valid value is ``_SSL_`` .
[-is-fips-enabled {true|false}]- FIPS Mode (privilege: advanced)-
Enables or disables FIPS-compliant mode for the entire cluster. Default is
false. [-supported-protocols {TLSv1.3|TLSv1.2|TLSv1.1|TLSv1|SSLv3}]- Supported Protocols (privilege: advanced)-
Selects the supported protocols for the selected interface. Default is
TLSv1.3,TLSv1.2 [-supported-ciphers <Cipher String>]- (DEPRECATED)-Supported Ciphers (privilege: advanced)-
This parameter has been deprecated in ONTAP 9.8 and may be removed in a future release of ONTAP. Use the supported-ciphers-suites parameter instead. Selects the supported cipher suites for the selected interface. Default is ``_ALL:!LOW:!aNULL:!EXP:!eNULL_`` .
[-supported-cipher-suites <Cipher String>,…]- Supported Cipher Suites (privilege: advanced)-
The following command enables FIPS mode in the cluster. (Default setting for FIPS mode is false )
cluster1::> security config modify * -is-fips-enabled true
The following command limits the supported protocols to just TLSv1.3 in the cluster. (Default setting for supported protocols is TLSv1.3,TLSv1.2 )
cluster1::*> security config modify * -supported-protocols TLSv1.3
The following command limits the supported cipher suites in the cluster to the listed ciphers.
cluster1::*> security config modify * -supported-cipher-suites TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384,TLS_AES_256_GCM_SHA384
