Command reference
storage aggregate inode-upgrade show
Display inode upgrade progress
The storage aggregate inode-upgrade show command displays information about aggregates undergoing the inode upgrade process. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the default fields about all aggregates undergoing the inode upgrade process. The default fields are:
  • aggregate
  • status
  • scan-percent
  • remaining-time
  • space-needed
  • scanner-progress
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-aggregate <text>] - Aggregate Name (privilege: advanced)
If this parameter is specified with the -node parameter, the command displays detailed information about the specified aggregate. If only this parameter is specified, the command displays information about all aggregates that match the specified name.
[-node <nodename>] - Node Name (privilege: advanced)
If this parameter is specified, the command displays information only about the aggregate or aggregates that are located on the specified node.
[-status {pending|scanning|suspended-initalizing|suspended|cleanup-pending|cleanup|cleanup-done|suspended-aborting|suspended-removing|suspended-while-removing|suspended-ironing}] - Upgrade Status (privilege: advanced)
If this parameter is specified, the command displays information only about the aggregate or aggregates that match the specified inode upgrade status.
[-scan-percent <percent>] - Upgrade Scan Percent Complete (privilege: advanced)
If this parameter is specified, the command displays information only about the aggregate or aggregates that match the specified inode upgrade progress percentage.
[-space-needed {<integer>[KB|MB|GB|TB|PB]}] - Space Needed to Complete Upgrade (privilege: advanced)
If this parameter is specified, the command displays information only about the aggregate or aggregates where the space needed to complete the upgrade process matches the specified size.
[-remaining-time <[<integer>d][<integer>h][<integer>m][<integer>s]>] - Remaining Upgrade Time (privilege: advanced)
If this parameter is specified, the command displays information only about the aggregate or aggregates where the remaining time to complete the inode upgrade process matches the specified time.
[-scanner-progress <text>] - Scanner Progress (privilege: advanced)
If this parameter is specified, the command displays information only about the aggregate or aggregates where the progress of the inode upgrade process matches the input.
The following example displays information about all aggregates undergoing the inode upgrade process:
cluster1::> storage aggregate inode-upgrade show
Aggregate Status    %Complete Time Remaining Space Needed Inode Progress
aggr0     pending   0%        -              20.36MB      Public : Inode 0 out of 65562
aggr1     pending   0%        -              19.84MB      Public : Inode 0 out of 63714
