network subnet show
Display subnet information
Display subnet information.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-ipspace <IPspace>]- IPspace Name-
Selects the subnets that match the given IPspace name.
 [-subnet-name <subnet name>]- Subnet Name-
Selects the subnets that match the given subnet name.
 [-broadcast-domain <Broadcast Domain>]- Broadcast Domain-
Selects the subnets that match the given broadcast domain name.
 [-subnet <IP Address/Mask>]- Layer 3 Subnet-
Selects the subnets that match the given address and mask.
 [-gateway <IP Address>]- Gateway-
Selects the subnets that match the given gateway address.
 [-ip-ranges {<ipaddr>|<ipaddr>-<ipaddr>}]- IP Addresses or IP Address Ranges-
Selects the subnets that match the given IP range.
 [-total-count <integer>]- Total Address Count-
Selects the subnets that match the given total address count.
 [-used-count <integer>]- Used Address Count-
Selects the subnets that match the given number of addresses allocated.
 [-available-count <integer>]- Available Address Count-
Selects the subnets that match the given number of addresses available.
The following example displays general information about the subnets.
cluster1::> network subnet show
IPspace: Default
     Subnet                     Broadcast                   Avail/
     Name      Subnet           Domain    Gateway           Total   Ranges
     s4        192.168.4.0/24   bd4       192.168.4.1        5/5    192.168.5.6-192.168.5.10
     s6        192.168.6.0/24   bd4       192.168.6.1        5/5    192.168.6.6-192.168.6.10
IPspace: ips1
     s10       192.168.6.0/24   bd10      192.168.6.1        0/0    -
     3 entries were displayed.
