ONTAP commands
network subnet show
Display subnet information
Display subnet information.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-ipspace <IPspace>] - IPspace Name
Selects the subnets that match the given IPspace name.
[-subnet-name <subnet name>] - Subnet Name
Selects the subnets that match the given subnet name.
[-broadcast-domain <Broadcast Domain>] - Broadcast Domain
Selects the subnets that match the given broadcast domain name.
[-subnet <IP Address/Mask>] - Layer 3 Subnet
Selects the subnets that match the given address and mask.
[-gateway <IP Address>] - Gateway
Selects the subnets that match the given gateway address.
[-ip-ranges {<ipaddr>|<ipaddr>-<ipaddr>}] - IP Addresses or IP Address Ranges
Selects the subnets that match the given IP range.
[-total-count <integer>] - Total Address Count
Selects the subnets that match the given total address count.
[-used-count <integer>] - Used Address Count
Selects the subnets that match the given number of addresses allocated.
[-available-count <integer>] - Available Address Count
Selects the subnets that match the given number of addresses available.
The following example displays general information about the subnets.
cluster1::> network subnet show
IPspace: Default
     Subnet                     Broadcast                   Avail/
     Name      Subnet           Domain    Gateway           Total   Ranges
     s4        192.168.4.0/24   bd4       192.168.4.1        5/5    192.168.5.6-192.168.5.10
     s6        192.168.6.0/24   bd4       192.168.6.1        5/5    192.168.6.6-192.168.6.10
IPspace: ips1
     s10       192.168.6.0/24   bd10      192.168.6.1        0/0    -
     3 entries were displayed.
