network subnet show
Display subnet information
Display subnet information.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-ipspace <IPspace>]- IPspace Name
Selects the subnets that match the given IPspace name.
- [-subnet-name <subnet name>]- Subnet Name
Selects the subnets that match the given subnet name.
- [-broadcast-domain <Broadcast Domain>]- Broadcast Domain
Selects the subnets that match the given broadcast domain name.
- [-subnet <IP Address/Mask>]- Layer 3 Subnet
Selects the subnets that match the given address and mask.
- [-gateway <IP Address>]- Gateway
Selects the subnets that match the given gateway address.
- [-ip-ranges {<ipaddr>|<ipaddr>-<ipaddr>}]- IP Addresses or IP Address Ranges
Selects the subnets that match the given IP range.
- [-total-count <integer>]- Total Address Count
Selects the subnets that match the given total address count.
- [-used-count <integer>]- Used Address Count
Selects the subnets that match the given number of addresses allocated.
- [-available-count <integer>]- Available Address Count
Selects the subnets that match the given number of addresses available.
The following example displays general information about the subnets.
cluster1::> network subnet show
IPspace: Default
     Subnet                     Broadcast                   Avail/
     Name      Subnet           Domain    Gateway           Total   Ranges
     s4        192.168.4.0/24   bd4       192.168.4.1        5/5    192.168.5.6-192.168.5.10
     s6        192.168.6.0/24   bd4       192.168.6.1        5/5    192.168.6.6-192.168.6.10
IPspace: ips1
     s10       192.168.6.0/24   bd10      192.168.6.1        0/0    -
     3 entries were displayed.
 PDFs
PDFs
